Mark I disagree with you on many points.
Napa does carry there brand of filter for a 5.0 Genesis (although it is there low end brand and I not going with that one.)
Does Napa make there own filters (I don't know) but there upper end filters are very highly rated in tests and have been recommended by engine builders that I personally know that build racing engines so I know there good.
Also not using synthetic being ridiculous I totally disagree with. Some rings will come unseated by using synthetic too early. Some motors come from factory and are built to use synthetic out of the factory (LS1 LS3 LT1 etc.) Synthetic has its advantages but for me I would rather use dinosaur oil and change it every 4k than use Synthetic and change every 10k.
My buddy sells Amsoil and I cant even justify using it in a 10k 604hp big block Ford. Instead I use Valvoline racing oil and change it twice a year.
I also don't believe that Walmart synthetic is superior to Valvoline racing oil but everyone has there opinion.
I do believe that synthetic is far superior when you do want to do less oil changes and dino oil breaks down way sooner. But for the cost difference I just feel better knowing my car has fresh oil every 4k miles
As far as the socket wrench I will have to check on that. Napa can get the factory filter for it for under 10 bucks. I don't know how much the factory charges but this Napa is by my house so I will use it.
King,
There are hundreds of posts on this forum which explain many of these points, and I hesitate to repeat them (you should probably find them yourself) but here is a summary.
Whatever tests that were done on "Napa" filters do not apply to the one for the Genesis, which is a low volume cartridge type filter, and not a mass market filter. So whatever you think about the quality of "main line" of Napa spin on filters, does not apply is this case. The filter "may" be the same one as the OEM filter (which is not made by Hyundai), but why even take a chance? I have read quite a few posts on this forum of people who got the wrong after-market filter, because the after-market filter guides are not correct (especially with the 2014 R-Spec).
There is no such thing anymore as a motor built to use synthetic. Maybe at one time, but not anymore. You may not know this, but almost all Toyotas and Hondas now specify synthetic oil (they actually specify 0W-20, which is only available as a synthetic, but don't want to use the word "synthetic" because it scares people who think synthetic is too expensive).
Since your engine is sufficiently broken in and rings seated, there is no problem in switching to synthetic now. If you want to be extra safe and switch to synthetic at 2nd oil change, then OK.
Amsoil is a complete and total ripoff. There are actually 3 different "grades" of Amsoil synthetic. The first one is very, very expensive, high quality synthetic polymers, but does not meet API specs for Hyundai engines and could void your warranty. The second and third grades are still over-priced and mediocre quality. Amsoil is a bait and switch scam.
Racing motor oil is usually too high of viscosity, does not meet manufacturer specs for Hyundai and will void your warranty (if there is an engine problem in any way related to oil and they find out what you used).
Valvoline no longer refines their own oil. They buy all the ingredients from others and just blend them. It is OK, but nothing special. They are living on the fumes of their glory days decades ago.
The price of a 5 quart jug of Mobil 1 at Walmart is about $25. You don't have to change your oil at 10,000 miles to justify synthetic, 5000 mile oil changes is fine. In fact, for warranty purposes you must change at least every 7500 miles.
No offense intended, but from almost everything you have said, you are living in the past. Things have changed a lot in the automotive business the last 10-15 years. The things you believe may have been true long ago, but were in the 21st century now.
It sounds to me like you enjoy talking the guys at the local Napa store, and there is nothing that I say that will convince you. Again, no personal offense toward you is intended, but I just feel telling the truth is important to forum members.
