2012 Genesis 5.0 Service Manuals
foleydb
The Hyundai Service Website (www.hmaservice.com) contains a lot of documentation about the various models of course. This might be way more information than anyone wants to know, but since it's there I thought I'd post it here on the forum. All of the sections are easily accessible.
For the 2012 Genesis 5.0 below is the table of contents for the different sections and subsections, with each item not in bold representing a page or many pages of specific documentation on that subject. It's too much info to fit in one post, so I'll continue the listing in replies:
SHOP
General Information
Engine Mechanical System
Engine Electrical System
Emission Control System
Fuel System
Automatic Transaxle System
Driveshaft and axle
Suspension System
Steering System
Restraint
Brake System
Body (Interior and Exterior)
Body Electrical System
Heating,Ventilation, Air Conditioning
ETM
General
Fuse & Relay Information
Power Distribution
Passenger Compartment Fuse Details
Ground Distribution
A/C Control System (Auto)
A/V Navigation
Adaptive Front Lighting System(AFLS)
Audio System
Auto Cruise System
Auto Headlamp Levelling System(AHLS)
Automatic Transaxle Control System
Back-Up Lamps
Charging System
Climate Seat Control System
Clock & Cigarette Lighter (Power Outlet) System
Cooling Sysetm
Courtesy & Trunk Lamps
Curtain System
Data Link Details
Defogger System
Driver Inforamtion System(DIS)
Electric Parking Brake (EPB)System
Electronic Active Headrest System
Electronic Stability Control (ESC)System
Fog Lamps
Front Area Module (FAM)
Fuel Filler Door & Trunk Lid opener
Head Lamps
Horns
Illuminations
Immobilizer Control
Indicator & Gauges
In-Panel Module (IPM)
Integrated Memory System(IMS)
Lane Departure Warning System (LDWS)
MFI Control System
Mobile Telematic System (MTS)
Parking Assist System
Power Distribution Module(PDM)
Power Door Locks
Power Outside Mirror System
Power Seat System
Power Steering System
Power Window System
Seat Warmer System
Shift Lock System
Starting System
Steering Tilt & Telescopic System
Steering Wheel Heating System
Stop Lamps
Sunroof System
Supplemental Restraint System(SRS)
Tail, Parking & License lamps
Tire Pressure Monitoring System (TPMS)
Turn & Hazard Lamps
Vehicle Speed System
Wiper & Washer System
Component Locations
Connector Configurations
Main Harness
Front Harness
Floor Harness
Control Harness
Door Harness
Roof Harness
Trunk Room & Trunk Lid Harness
Air Bag Harness
FEM Harness
Battery Harness
Seat Harness
DTC
Air Conditioner > Air Conditioner
B1204 Air Mix Potentiometer Open (Low)–Passenger
B1205 Air Mix Potentiometer Short (High)–Passenger
B1208 Intake Potentiometer Open (Low)
B1209 Intake Potentiometer Short (High)
B1233 In-Car Temperature Sensor Short (Low)
B1234 In-Car Temperature Sensor Open (High)
B1237 Ambient Temperature Sensor Short (Low)
B1238 Ambient Temperature Sensor Open (High)
B1241 Evaporator Sensor Short (Low)
B1242 Evaporator Sensor Open (High)
B1245 Air Mix Potentiometer Open (Low)-Driver
B1246 Air Mix Potentiometer Short (High)-Driver
B1249 Direction Potentiometer Open (Low)-Driver
B1250 Direction Potentiometer Short (High)-Driver
B1257 AQS Sensor Open
B1258 AQS Sensor Short
B1259 AQS Sensor Fault
B1275 Air Mix Potentiometer-VENT Open (Low)–Console
B1276 Air Mix Potentiometer VENT Short (High)–Console
B1277 Air Mix Potentiometer-TEMP Open (Low)–Console
B1278 Air Mix Potentiometer-TEMP Short (High)–Console
B1279 Air Mix Switch Potentiometer Open (Low)–Console
B1280 Air Mix Switch Potentiometer Short (High)–Console
B1281 Humidity Sensor Short (Low) – AUTO Defog
B1282 Humidity Sensor Open (High) - AUTO Defog
B1283 Direction Potentiometer Open (Low) - AUTO Defog
B1284 Direction Potentiometer Short (High) - Auto Defog
B1285 Direction Control Motor -AUTO Defog
B1672 APT Sensor Fault – CAN Signal
B1686 Vehicle Speed Sensor Fault – CAN Signal
B1687 Engine Coolant Temperature Sensor Circuit - CAN Signal
B2406 Air Mix Motor-Driver
B2408 Intake Motor
B2409 Direction Control Motor-Driver
B2415 Air Mix Door Motor-Passenger
B2447 Air Mix Motor VENT-Console
B2448 Air Mix Motor TEMP-Console
Airbag > Airbag(Event #1)
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1326 FIS(Front Impact Sensor)-Driver Short to Ground
B1327 FIS(Front Impact Sensor)-Driver Short to Battery
B1328 FIS(Front Impact Sensor)-Driver Defect
B1329 FIS(Front Impact Sensor)-Driver Communication error
B1330 FIS(Front Impact Sensor)-Driver Wrong ID
B1331 FIS(Front Impact Sensor)-Passenger Short to Ground
B1332 FIS(Front Impact Sensor)-Passenger Short to Battery
B1333 FIS(Front Impact Sensor)-Passenger Defect
B1334 FIS(Front Impact Sensor)-Passenger Communication error
B1335 FIS(Front Impact Sensor)-Passenger Wrong ID
B1346 Driver Airbag Resistance too High (1st stage)
B1347 Driver Airbag Resistance too Low (1st stage)
B1348 Driver Airbag resistance circuit short to Ground (1st stage)
B1349 Driver Airbag resistance circuit short to Battery (1st stage)
B1352 Passenger Airbag Resistance too High (1st Stage)
B1353 Passenger Airbag Resistance too Low (1st stage)
B1354 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B1355 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B1361 Pretensioner Front-Driver Resistance too High
B1362 Pretensioner Front-Driver Resistance too Low
B1363 Pretensioner front-Driver resistance circuit short to Ground
B1364 Pretensioner front-Driver resistance circuit short to Battery
B1367 Pretensioner Front-Passenger Resistance too High
B1368 Pretensioner Front-Passenger Resistance too Low
B1369 Pretensioner Front-Passenger Resistance Circuit Short to Ground
B1370 Pretensioner Front-Passenger Resistance Circuit Short to Battery
B1378 Side Airbag Front-Driver Resistance too High
B1379 Side Airbag Front-Driver Resistance too Low
B1380 Side Airbag Front-Driver Resistance Circuit Short to Ground
B1381 Side Airbag Front-Driver Resistance Circuit Short to Battery
B1382 Side Airbag Front-Passenger Resistance too High
B1383 Side Airbag Front-Passenger Resistance too Low
B1384 Side Airbag Front-Passenger Resistance Circuit Short to Ground
B1385 Side Airbag Front-Passenger Resistance Circuit Short to Battery
B1395 Firing Loops Interconnection Fault
B1400 SIS(Side Impact Sensor) Front-Driver defect
B1401 SIS(Side Impact Sensor)Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor)Front-Driver Circuit Short to Battery
B1403 SIS(Side Impact Sensor)Front-Passenger Defect
B1404 SIS(Side Impact Sensor)Front-Passenger Circuit Short to Ground
B1405 SIS(Side Impact Sensor)Front-Passenger Circuit Short to Battery
B1409 SIS(Side Impact Sensor) Front-Driver Communication Error
B1410 SIS(Side Impact Sensor) Front-Passenger Communication Error
B1412 SIS(Side Impact Sensor)Rear-Driver Communication error
B1413 SIS(Side Impact Sensor)Rear-Passenger Communication error
B1414 SIS(Side Impact Sensor) Front-Driver Wrong ID
B1415 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B1416 SIS(Side Impact Sensor)Rear-Driver Wrong ID
B1417 SIS(Side Impact Sensor)Rear-Passenger Wrong ID
B1418 SIS(Side Impact Sensor)Rear-Driver Defect
B1419 SIS(Side Impact Sensor)Rear-Passenger Defect
B1429 Side Airbag Rear-Driver Resistance too High
B1430 Side Airbag Rear-Driver Resistance too Low
B1431 Side Airbag Rear-Driver Resistance Circuit Short to Ground
B1432 Side Airbag Rear-Driver Resistance Circuit Short to Battery
B1433 Side Airbag Rear-Passenger Resistance too High
B1434 Side Airbag Rear-Passenger Resistance too Low
B1435 Side Airbag Rear-Passenger Resistance Circuit Short to Ground
B1436 Side Airbag Rear-Passenger Resistance Circuit Short to Battery
B1451 SIS(Side Impact Sensor)rear-Driver Circuit Short to Ground
B1452 SIS(Side Impact Sensor)Rear-Driver Circuit Short to Battery
B1454 SIS(Side Impact Sensor)Rear-Passenger Circuit Short to Ground
B1455 SIS(Side Impact Sensor)Rear-Passenger Circuit Short to Battery
B1473 Inflatable Curtain Airbag Front-Driver Resistance too High
B1474 Inflatable Curtain Airbag Front-Driver Resistance too Low
B1475 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Inflatable Curtain Airbag Front-Passenger Resistance too High
B1478 Inflatable Curtain Airbag Front-Passenger Resistance too Low
B1479 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1481 Driver Airbag Resistance too High(2nd stage)
B1482 Driver Airbag Resistance too Low(2nd stage)
B1483 Driver Airbag Resistance Circuit Short to Ground(2nd stage)
B1484 Driver Airbag Resistance Circuit Short to Battery(2nd stage)
B1485 Passenger Airbag Resistance too High(2nd stage)
B1486 Passenger Airbag Resistance too Low(2nd stage)
B1487 Passenger Airbag Resistance Circuit Short to Ground(2nd stage)
B1488 Passenger Airbag Resistance Circuit Short to Battery(2nd stage)
B1489 PODS(Passenger Occupant Detecting System) ECU Defect
B1490 PODS(Passenger Occupant Detecting System) Sensor(Bladder) Defect
B1493 PODS(Passenger Occupant Detecting System) Communication error
B1494 PODS(Passenger Occupant Detecting System) Wrong ID
B1495 BTS(Belt-Tension Sensor) Defect
B1496 PODS(Passenger Occupant Detecting System)Not calibrated
B1511 Buckle Switch Driver open or short to Battery
B1512 Buckle Switch Driver short or short to Ground
B1513 Buckle Switch Passenger open or short to Battery
B1514 Buckle Switch Passenger short or short to Ground
B1515 Buckle Switch Driver Defect
B1516 Buckle Switch Passenger Defect
B1517 Buckle Switch Driver Instability
B1518 Buckle Switch Passenger instability
B1620 Internal fault-Replace SRSCM
B1650 Crash Recorded in 1st Stage Only(Frontal-Replace SRSCM)
B1651 Crash Recorded in Front-Driver Side Airbag(Replace SRSCM)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace SRSCM)
B1670 Crash recorded in full stage(Frontal-Replace SRSCM)
B2500 Warning lamp Failure
B2502 Passenger Airbag Telltale Lamp Failure
Airbag > Airbag(Event #2)
Body Control > Assist Door Module
B1602 CAN Error
B1603 CAN Communication Bus Off
B1912 Outside Mirror - Right horizontal Motor or Sensor
B1913 Outside Mirror - Right vertical Motor or Sensor
Body Control > Cluster Module
B1602 CAN Error
B1562 Fuel Sender ERR
Body Control > Driver Door Module
B1602 CAN Error
B1681 DDM and Rear LH Serial Communication Error
B1682 DDM and Rear RH Serial Communication Error
B1910 Outside Mirror - Left Horizontal Motor or Sensor Error
B1911 Outside Mirror - Left Vertical Motor or Sensor Error
Body Control > Electric Control Wiper
B1602 CAN Error
Body Control > Front Area Module
B1602 CAN Error
B1905 Rain Sensor Fault 1
B1906 Rain Sensor Fault 2
B1907 Rain Sensor Fault 3
Body Control > Front Back Warning System
B1602 CAN Error
B1621 Power Error
B1210 Front Left Sensor Fault
B1211 Front Center Left Sensor Fault
B1212 Front Center Right Sensor Fault
B1213 Front Right Sensor Fault
B1214 Rear Left Sensor Fault
B1215 Rear Center Left Sensor Fault
B1216 Rear Center Right Sensor Fault
B1217 Rear Right Sensor Fault
Body Control > Instrument Panel Module(W/O PIC)
B1602 CAN Error
B1605 CAN Time-out DDM
B1606 CAN Time-out ADM
B1607 CAN Time-out P/SEAT
B1608 CAN Time-out TILT/TELE
B1611 CAN Time-out FAM
B1613 CAN Time-out CLU
B1625 ECM Communication Data Failure
B1640 CAN Time-out MFSW
B1641 CAN Time-out FBWS
B1642 CAN Time-out PTM
B1643 CAN Time-out ECW
B1689 CAN Time-out PDM
B1978 Electric Steering Column Lock Failure
B1971 Parking Position Input Error
Body Control > Multi Function Switch
B1550 Cruise Switch Error
B1551 Audio1 Switch Error
B1552 Audio2 Switch Error
B1553 Light Multifunction Switch Error
B1554 Turn Signal Multifunction Switch Error
B1555 Wiper Multifunction Switch Error
B1602 CAN Error
Body Control > Power Distribution Module
B1602 CAN Error
B1987 Sub Micom Failed
B1988 ESCL Battery Short Circuit To Battery
B1989 ESCL Ground Short Circuit To Battery
B1990 ESCL Battery Short Circuit To Ground
B1991 Immobilizer TX Short Circuit To Ground
Body Control > Power Seat Module
B1602 CAN Error
B1954 Slide Motor Or Sensor Error
B1955 Recline Motor Or Sensor Error
B1956 Front Height Motor Or Sensor Error
B1957 Rear Height Motor Or Sensor Error
Body Control > Power Trunk Module
B1602 CAN Error
B1621 ECU Check Sum Error
B2458 Power Striker Motor and Switch Error
B2459 Latch Motor and Switch Error
B2460 Drive Motor and Hall Sensor Error
Body Control > Steering Column Module
B1602 CAN Error
B1959 Tilt Position Sensor Error
B1960 Tele Position Sensor Error
Brake > Electronic Stability Control
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1200 Wheel Speed Sensor Front-LH Open/Short
C1201 Wheel Speed Sensor Front-LH Range / Performance / Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/no Signal
C1203 Wheel Speed Sensor Front-RH Open/Short
C1204 Wheel Speed Sensor Front-RH Range / Performance / Intermittent
C1205 Wheel Speed Sensor Front-RH Invalid/no Signal
C1206 Wheel Speed Sensor Rear-LH Open/Short
C1207 Wheel Speed Sensor Rear-LH Range / Performance / Intermittent
C1208 Wheel Speed Sensor Rear-LH Invalid/no Signal
C1209 Wheel Speed Sensor Rear-RH Open/Short
C1210 Wheel Speed Sensor Rear-RH Range / Performance / Intermittent
C1211 Wheel Speed Sensor Rear-RH Invalid/no Signal
C1235 Primary Pressure Sensor-Electrical
C1237 Primary Pressure Sensor-Signal
C1260 Steering Angle Sensor Circuit-Signal
C1261 Steering Angle Sensor Not Calibrated
C1274 Longitudinal G Sensor-Electrical
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yaw Rate & Lateral G Sensor-Electrical
C1283 Yaw Rate & Lateral G Sensor-Signal
C1353 Pressure sensor (Wh1) – electrical
C1354 Pressure sensor (Wh1) – other
C1355 Pressure sensor (Wh2) – electrical
C1356 Pressure sensor (Wh2) – other
C1357 SCC or DBF deceleration plausibility error
C1358 AVH not Available due to EPB in Emergency Release
C1359 SCC Control Unit Error
C1503 TCS/ESC(ESP) Switch error
C1513 Brake switch error
C1604 ECU Hardware Error
C1605 CAN Hardware error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN signal error ECM (Check ECM)
C1616 CAN Communication Bus Off
C1623 CAN Time-out Steering Angle Sensor
C1626 Implausible Control
C1638 CAN time-out SCC
C1648 CAN signal error ECM for SCC (Check ECM)
C1649 CAN time-out ECM for SCC
C1650 CAN signal error SCC
C1651 CAN time-out EPB
C1652 CAN signal error EPB
C1653 CAN time-out Cluster for SCC
C1654 CAN time-out Cluster for EPB
C1655 CAN signal error TCU for EPB
C1702 Variant Coding Error
C2112 Valve Relay Error
C2227 Excessive Temperature Of Brake Disc
C2228 CAN signal error TCM for SCC
C2308 Front-LH Valve error (Inlet Valve)
C2312 Front-LH Valve error (Outlet Valve)
C2316 Front-RH Valve error (Inlet Valve)
C2320 Front-RH Valve error (Outlet Valve)
C2324 Rear-LH Valve error (Inlet Valve)
C2328 Rear-LH Valve error (Outlet Valve)
C2332 Rear-RH Valve error (Inlet Valve)
C2336 Rear-RH Valve error (Outlet Valve)
C2366 TC Valve Primary (USV1) Error
C2370 TC Valve Secondary (USV2) Error
C2372 Electronic Shuttle Valve Primary (HSV1) Error
C2374 Electronic Shuttle Valve Secondary (HSV2) Error
C2380 ABS/TCS/ESP valve error
C2402 Motor Failure
Cruise Control > Smart Cruise Control
C1360 ESP Irreversible Error
C1603 ECU Internal Thermal & Voltage Error
C1605 CAN Hardware Error
C1606 ECU Software Error
C1611 CAN Time-out EMS
C1612 CAN Time-out TCU
C1613 CAN signal error EMS
C1616 CAN Bus Off
C1617 EMS Invalid Engine Speed
C1620 ALIGNMENT FAILED
C1622 EMS invalid vehicle speed
C1625 CAN Time-out ABS/ESP
C1628 CAN Timeout - Cluster
C1629 Cluster Invalid Counter
C1632 Cluster Control Switch Fail
C1633 Cluster Invalid Displayed Speed
C1634 Speed Correction Signal Error
C1635 TCS Invalid Counter
C1636 TCS Invalid ACCEL_REF_ACC
C1637 TCS Invalid aBasis
C1638 ACC communication error
C1642 CAN signal error ESC
C1646 CAN signal error TCU
C1680 VSM EBS Error
DIS > Head Unit
U1000 Head Unit ECM Error
U1003 Temperature Sensor Signal Error in Head Unit
U1006 Low Voltage Detected
U1007 High Voltage Detected
U1500 Wakeup Line Short Circuit To Ground
U1501 Wakeup Line Short Circuit To Vcc
U1540 Wakeup Line Test Failed at Amplifier Unit
U1900 GPS Antenna Line Break
U1920 DVD Drive Error
U1940 Front Display SDC Communication Error
U1942 Rear Display SDC Communication Error
U1970 Multimedia CAN Bus Off Error
U1971 Multimedia CAN Single Line Error
U1972 Multimedia CAN Limp Home Status
U1980 Timeout Multimedia CAN Message(Air Conditioner, Cluster, Audio)
U1981 Timeout Multimedia CAN Message(Vehicle Speed)
U1982 Timeout Multimedia CAN Message(Body CAN Signal - Camera, ECS, Trip Computer, Alternator, Auto Light)
U1983 Timeout Multimedia CAN Message (Trip Computer)
U1984 Timeout Multimedia CAN Message(Inhibitor Signal)
DIS > Tuner/Amplifier
U1000 Amplifer Unit Error
U1001 HW Watchdog Executed
U1004 Temperature Sensor Signal Error in Tunner and Amplifier
U1010 Low Voltage Detected
U1011 High Voltage Detected
U1138 Fan Operation Error(Fan is running although should be off)
U1139 Fan Operation Error - no plug put or line open(Fan is not running although it should be on)
U1601 Data Upgrade Error - Application Software Code 1 Missing or Corrupted
U1602 Data Upgrade Error - Application Software Code 2 Missing or Corrupted
U1606 Data Upgrade Error - Application Software Data Missing or Corrupted
U1700 DTCP Sink SW error.
U1702 DTCP Sink Decode error.
U1710 Amplifier stage group 1 Error - S/Woofer 1(+), 1(-) short circuit
U1711 Amplifier stage group 2 Error - S/Woofer 2(+), 2(-) short circuit
U1712 Amplifier stage group 3 Error - Front Middle/Tweeter LH & RH short circuit
U1713 Amplifier stage group 4 Error - DECK LH, DECK RH, Center Speaker short circuit
U1714 Amplifier stage group 5 Error - Front LH & RH short circuit
U1941 AmFm Antenna circuit Open ( not connected )
U1942 Fm2 Antenna circuit Low
U1943 Fm2 Antenna circuit Open
U1944 XM Antenna circuit Low (UTA US only)
U1945 XM Antenna circuit Open (UTA US only)
DIS > Voice Recognition System
U1001 Microphone 1 not connected
U1002 Microphone 1 shortcut
Engine > Engine Control
P0011 'A' Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P0014 'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position – Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position-Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position – Camshaft Position Correlation (Bank 2 Sensor B)
P0021 'A' Camshaft Position-Timing Over-Advanced or System Performance (Bank 2)
P0024 'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P0050 HO2S Heater Control Circuit (Bank 2 / Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 / Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 / Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 / Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 / Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 / Sensor 2)
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit-High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit-Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit-High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0090 Fuel Pressure Regulator 1 Control Circuit/Open
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0116 Engine Coolant Temperature Circuit Range / Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P011B Engine Coolant Temperature/Intake Air Temperature Correlation
P0121 Throttle Position Sensor 1 Signal Circuit Range/Performance
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0128 Coolant Thermostat (Coolant Temperature below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit(Bank 1 / Sensor 1)
P0131 O2 Sensor Circuit Low Voltage(Bank 1 / Sensor 1)
P0132 O2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit(Bank 1 / Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 / Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 / Sensor 2)
P0139 O2 Sensor Circuit Slow Response(Bank 1 / Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0150 O2 Sensor Circuit(Bank 2 / Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 1)
P0156 O2 Sensor Circuit (Bank 2 / Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 2)
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0201 Injector Circuit/Open-Cylinder 1
P0202 Injector Circuit/Open-Cylinder 2
P0203 Injector Circuit/Open-Cylinder 3
P0204 Injector Circuit/Open-Cylinder 4
P0205 Injector Circuit/Open-Cylinder 5
P0206 Injector Circuit/Open-Cylinder 6
P0207 Injector Circuit/Open – Cylinder 7
P0208 Injector Circuit/Open – Cylinder 8
P020A Cylinder 1 Injector Timing (Injector Input Line Circuit Error)
P020B Cylinder 2 Injector Timing (Injector Input Line Circuit Error)
P020C Cylinder 3 Injector Timing (Injector Input Line Circuit Error)
P020D Cylinder 4 Injector Timing (Injector Input Line Circuit Error)
P020E Cylinder 5 Injector Timing (Injector Input Line Circuit Error)
P020F Cylinder 6 Injector Timing (Injector Input Line Circuit Error)
P021A Cylinder 7 Injector Timing (Injector Input Line Circuit Error)
P021B Cylinder 8 Injector Timing (Injector Input Line Circuit Error)
P0221 Throttle Position Sensor 2 Signal Circuit Range/Performance
P0222 Throttle Position Sensor 2 Signal Circuit Low Input
P0223 Throttle Position Sensor 2 Signal Circuit High Input
P0230 Fuel Pump Primary Circuit
P0253 Injection Pump Fuel Metering Control 'A' Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control 'A' High (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control 'B' Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control 'B' High (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1-Misfire detected
P0302 Cylinder 2-Misfire detected
P0303 Cylinder 3-Misfire detected
P0304 Cylinder 4-Misfire detected
P0305 Cylinder 5-Misfire detected
P0306 Cylinder 6-Misfire detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P032B Knock Sensor 3 Circuit Range/Performance
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0335 Crankshaft Position Sensor 'A' Circuit
P0336 Crankshaft Position Sensor 'A' Circuit Range/Performance
P033B Knock Sensor 4 Circuit Range/Performance
P0340 Camshaft Position Sensor 'A' Circuit (Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0345 Camshaft Position Sensor 'A' Circuit (Bank 2)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0365 Camshaft Position Sensor B Circuit Malfunction (Bank 1)
P0366 Camshaft Position Sensor 'B' Circuit Range/Performance (Bank 1)
P0390 Camshaft Position Sensor 'B' Circuit (Bank 2)
P0391 Camshaft Position Sensor 'B' Circuit Range/Performance (Bank 2)
P0420 Catalyst System Efficiency below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System-Leak detected (small leak)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0447 Evaporative Emission System-Vent Control Circuit Open
P0448 Evaporative Emission System - Vent Control Circuit Shorted
P0449 Evaporative Emission System-Vent Valve / Solenoid Circuit
P0451 Evaporative Emission System-Pressure Sensor Range / Performance
P0452 Evaporative Emission System-Pressure Sensor Low Input
P0453 Evaporative Emission System-Pressure Sensor High Input
P0455 Evaporative Emission System-Leak detected(Large leak)
P0456 Evaporative Emission System-Leak detected (very small leak)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0461 Fuel Level Sensor 'A' Circuit Range/Performance
P0462 Fuel Level Sensor 'A' Circuit Low Input
P0463 Fuel Level Sensor 'A' Circuit High Input
P0504 Brake Switch 'A' / 'B' Correlation
P0506 Idle Air Control System-RPM Lower than Expected
P0507 Idle Air Control System-RPM Higher than Expected
P0532 A/C Refrigerant Pressure Sensor 'A' Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor 'A' Circuit High Input
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0564 Cruise Control Multi-Function Input A Circuit
P0605 Internal Control Module Read Only Memory(ROM) Error
P0606 ECM/PCM Processor
P0611 Fuel Injector Control Module Performance
P061B Internal Control Module Torque Calculation Performance
P0625 Generator Field/ F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P0627 Fuel Pump 'A' Control Circuit/Open
P0630 VIN Not Programmed or Incompatible-ECM/PCM
P0638 Throttle Actuator Control Range/Performance (Bank 1)
P0642 Sensor Reference Voltage 'A' Circuit Low
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Control Circuit Low
P0647 A/C Clutch Relay Control Circuit High
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0652 Sensor Reference Voltage 'B' Circuit Low
P0698 Sensor Reference Voltage 'C' Circuit Low
P0704 Clutch Switch Input Circuit Malfunction
P2066 Fuel Level Sensor 'B' Performance
P2067 Fuel Level Sensor 'B' Circuit Low
P2068 Fuel Level Sensor 'B' Circuit High
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2098 Post Catalyst Fuel Trim System Too Lean (Bank 2)
P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2104 Limp Home Mode - Forced Idle
P2106 Limp Home Mode - Force Limited Power
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2122 Accelerator Position Sensor 1 Signal Circuit Low Input
P2123 Accelerator Position Sensor 1 Signal Circuit High Input
P2127 Accelerator Position Sensor 2 Signal Circuit Low Input
P2128 Accelerator Position Sensor 2 Signal Circuit-High Input
P2138 Accelerator Position Sensor 1 & 2 Signal Voltage Correlation
P2159 Vehicle Speed Sensor 'B' Range / Performance(Wheel Speed Sensor)
P2187 System too Lean at Idle (←Additive) (Bank 1)
P2188 System too Rich at Idle (Bank 1)
P2189 System too Lean at Idle (- Additive) (Bank 2)
P2190 System too Rich at Idle (Bank 2)
P2191 System too Lean at Higher Load (Multiple) (Bank 1)
P2192 System too Rich at Higher Load (Bank 1)
P2193 System Too Lean at Higher Load (←Multiple) (Bank 2)
P2194 System Too Rich at Higher Load (Bank 2)
P2270 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2)
P2271 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2)
P2272 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 2)
P2273 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2)
P2294 Fuel Pressure Regulator 2 Control Circuit
P2295 Fuel Pressure Regulator 2 Control Circuit Low
P2296 Fuel Pressure Regulator 2 Control Circuit High
P2502 Charging System Voltage
P2610 ECM / PCM-Engine Off Timer Performance
P2632 Fuel Pump 'B' Control Circuit/Open
U0001 High Speed CAN Communication Bus off (C-CAN)
U0100 Lost Communication With ECM/PCM 'A' (C-CAN)
U0101 Lost Communication with TCM (C-CAN)
U0105 Lost Communication With Fuel Injector Control Module
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
Head Lamp > AFLS(LED)
B1220 Vehicle Speed Sensor
B1301 Steering angle signal fault
B1302 Gearbox Signal Fault-CAN Signal
B1303 Accelerator Pedal Position Signal Error
B1304 Engine state signal fault
B1305 Yaw Rate Sensor Signal Fault
B1306 Brake pedal signal fault
B1308 Lamp Function Signal Fault
B1621 ECU Hardware Error
B1622 ECU Software Error
B1636 LIN Communication Error Fault
B1637 System Not Initialized
B1639 LIN communication error DBL(Dynamic Bending Light) left
B1661 Parameter Fault And Missing
B1905 Sensor Power Supply Fault
B1906 Front sensor PWM signal fault
B1907 Front sensor signal fault
B1908 Rear sensor PWM signal fault
B1909 Rear sensor signal fault
B1953 AXLE Sensor Fault
B2200 LIN communication error DBL(Dynamic Bending Light) Right
B2201 LIN communication error HLL(Head Lamp Leveling) Left
B2202 LIN communication error HLL(Head Lamp Leveling) Right
B2325 Swivel module fault left
B2326 Swivel module fault right
B2400 Levelling motor fault left
B2401 Levelling motor fault right
Immobilizer > Immobilizer
P1610 Non-Immobilizer-EMS Connected to an Immobilizer
P1674 Immobilizer-Transponder status Error
P1675 Immobilizer-Transponder Programming Error
P1676 Immobilizer-Smartra Message Error
P1690 Immobilizer-Smartra No Response
P1691 Immobilizer-Antenna Coil Error
P1692 Immobilizer Indicator Lamp Error
P1693 Immobilizer-Transponder Error
P1694 Immobilizer-EMS Message Error
P1695 Immobilizer-EMS Memory Error
P1696 Immobilizer-Authentication Fail
P1699 Immobilizer-Twice Overtrial
P169A Immobilizer-SMARTRA Authentication Fail
Parking Brake > Electric Parking Brake
C1103 Ignition Signal Failure
C1241 Force Sensor Failure
C1242 Force Sensor Not Calibrated
C1262 Temperature Sensor Failure
C1270 Temperature / Overload
C1501 Switch Failure
C1616 CAN Bus off
C1625 CAN Time-out ABS/ESC(ESP)
C1642 CAN signal error ESC(ESP)
C1656 CAN signal error Cluster
C2202 Latching Failure / Mechanics
C2402 Motor Electrical
Steering > Electric Hydraulic Power Steering
C1603 ECU thermal protection
C2400 Motor Fault - Motor Not Running
C2413 Motor current fail (current over)
C2420 Motor temperature sensor high input
C2421 Motor Temperature Sensor Low Input
Tire Pressure Monitoring > Tire Pressure Monitoring System
C1121 Front Left Sensor Battery Voltage Low
C1122 Front Right Sensor Battery Voltage Low
C1123 Rear Left Sensor Battery Voltage Low
C1124 Rear Right Sensor Battery Voltage Low
C1126 TPMS ECU Battery Voltage Low
C1127 TPMS ECU Battery Voltage High
C1212 First Speed Input Fault
C1240 Second Speed Input Fault
C1300 LF/RF External Interference Failure
C1306 RF Internal Interference Failure
C1312 Front Left Sensor RF Channel Failure
C1313 Front Right Sensor RF Channel Failure
C1314 Rear Left Sensor RF Channel Failure
C1315 Rear Right Sensor RF Channel Failure
C1322 Front Left Sensor Over Temperature
C1323 Front Right Sensor Over Temperature
C1324 Rear Left Sensor Over Temperature
C1325 Rear Right Sensor Over Temperature
C1332 Front Left Sensor Fault
C1333 Front Right Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1345 Front Low Frequency Initiator Channel Failure
C1346 Rear Low Frequency Initiator Channel Failure
C1660 Receiver Radio Frequency Circuit Failure
C1661 Receiver EEPROM Failure
C1664 Initiator/LF/RF Circuit Failure Not Affecting RSSI Level(High Line Only)
C1665 Initiator supply circuit short to ground
C1666 Initiator supply circuit short to battery
C1668 Internal failure detection
C2510 TREAD LAMP open/short circuit
C2512 Front Left LAMP open/short circuit
C2513 Front Right LAMP open/short circuit
C2514 Rear Left LAMP open/short circuit
C2515 Rear Right LAMP open/short circuit
Transmission > A8TR1
P0601 Internal Control Module Memory Check Sum Error
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0711 Transmission Fluid Temperature Sensor 'A' Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor 'A' Circuit Low Input
P0713 Transmission Fluid Temperature Sensor 'A' Circuit High Input
P0717 Input/Turbine Speed Sensor 'A' Circuit No Signal
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0729 Gear 6 Incorrect Ratio
P0730 Gear 8 Incorrect Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0743 Torque Converter Clutch Circuit Electrical
P0748 Pressure Control Solenoid Valve(VFS) 'A' Electrical
P0753 Shift Control Solenoid Valve 'A' Electical (UD/B)
P0758 Shift Control Solenoid Valve 'B' Electrical (2-6/B)
P075A ON/OFF Solenoid
P0763 Shift Control Solenoid Valve 'C' Electrical (35R/C)
P0768 Shift Control Solenoid Valve 'D' Electrical (OD/C)
P076F Gear 7 Incorrect Ratio
P0773 Shift Control Solenoid Valve 'E' Electrical (SS-A)
P0791 Middle Speed Sensor Circuit No Signal
P0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
P0880 TCM Power Signal Error Open/Short (GND)
P0881 TCM Power Input Signal Range/Performance
P2709 Shift Control Solenoid Valve 'F' Electrical (SS-B)
TSB
Automatic Transaxle (57)
12-AT-011 AUTOMATIC TRANSAXLE HARSH AND/OR DELAYED SHIFT – GDS ANALYSIS
12-AT-010 AUTOMATIC TRANSMISSION OIL PRESSURE DATA TRANSFER
12-AT-006-1 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
12-AT-006 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
12-AT-005 AUTOMATIC TRANSMISSION STALL TEST PROCEDURE
12-AT-004-1 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
12-AT-004 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
12-AT-001 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
11-AT-008-1 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VAL
11-AT-020 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
11-AT-017-1 AUTOMATIC TRANSMISSION SOLENOID& SENSOR DTC P0741, P0743, P0748, P0
11-AT-017 AUTOMATIC TRANSMISSION SOLENOID& SENSOR DTC P0741, P0743, P0748, P075
11-AT-016-1 ATM OIL TEMPERATURE SENSOR DTC P0711, P0712 & P0713
11-AT-016 ATM OIL TEMPERATURE SENSOR DTC P0711, P0712 & P0713
11-AT-015-1 ATM INPUT, MIDDLE AND OUTPUT SPEED SENSOR DTC P0717, P0721, P0722 &
11-AT-015 ATM INPUT, MIDDLE AND OUTPUT SPEED SENSOR DTC P0717, P0721, P0722 & P
11-AT-013 AUTOMATIC TRANSMISSION OIL PRESSURE DATA TRANSFER
11-AT-012 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
11-AT-008 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
11-AT-006 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
11-AT-005 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
10-AT-011 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
10-AT-008 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
10-AT-002 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
09-AT-008 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
09-AT-007 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
09-AT-006 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
09-AT-002-1 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VAL
09-AT-002 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
09-AT-001 GENESIS COUPE V6 AND GENESIS V8 AUTOMATIC TRANSMISSION FLUID LEVEL
08-AT-013 NEUTRAL START SWITCH ADJUSTMENT 2009~ GENESIS 3.8L V6
08-AT-010 Revised. See 09-AT-007
08-AT-008 GENESIS V8 AUTOMATIC TRANSAXLE FLUID LEVEL
08-AT-007 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
07-40-011 AUTOMATIC TRANSAXLE OIL COOLER FLUSHING
07-40-007 Revised. See 09-AT-008
07-40-006 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
06-40-016 AUTOMATIC TRANSAXLE FLUID LEVEL
06-40-014 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
06-40-012 OIL LEAK FROM DIFFERENTIAL OIL SEALS
06-40-005 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUES
06-40-002 AUTOMATIC TRANSAXLE OIL LEAK BEHIND TORQUE CONVERTER
05-40-016 AUTOMATIC TRANSAXLE - NO MOVEMENT IN DRIVE OR REVERSE GEAR
05-40-012 AUTOMATIC TRANSAXLE INSTALLATION PROCEDURE TO PREVENT DAMAGE TO OIL PU
05-40-005 UPDATED ATM DIAGNOSIS WORKSHEET
04-40-021 AUTOMATIC TRANSAXLE TORQUE CONVERTER INSPECTION
04-40-016 AUTOMATIC TRANSAXLE DIAGNOSTIC TROUBLE CODE P0711, P0712 AND P0713
04-40-009-1 AUTOMATIC TRANSAXLE DIFFERENTIAL OIL SEAL INSTALLER
03-40-013 Automatic Transaxle Range Switch Diagnostic Trouble Codes P0705, P0707
03-40-005 Automatic Transaxle Diagnostic Trouble Codes P0731, P0732, P0733, P073
03-40-003 Automatic Transaxle Control Module Adaptive Learning
02-40-018-1 Automatic Transaxle - Cruise Control Operation
02-40-018 Automatic Transaxle - Cruise Control Operation
02-40-007 Automatic Transaxle Torque Converter Clutch Diagnosis
01-40-021 Oil Leak Behind Torque Converter
01-40-004 Remanufactured Automatic Transaxle (ATM) Program
01-40-002 Automatic Transaxle Control Module Adaptive Learning
Body (Interior and Exterior) (11)
09-BD-011 SUNROOF CREAK / TICK NOISE REPAIR
09-BD-010 BODY DIMENSION INFORMATION
09-BD-003 ALUMINUM WHEEL CLEANING AND MAINTENANCE
07-99-001 CLOUDED PAINT CORRECTIVE PROCEDURE
07-90-002 PROGRAMMING HOMELINK MIRROR TO GARAGE DOOR RECEIVERS WITH ROLLING CODE
05-80-003 SEAT INSTALLATION PROCEDURES
05-00-001 RECREATIONAL TOWING REQUIREMENTS
04-80-002 ROUND MARKS ON THE INSIDE GLASS SURFACES
00-99-001 CLOUDED PAINT CORRECTIVE PROCEDURE
99-99-001 PAINT EXAMINATION, REPAIR AND PREVENTIVE STEPS FOR ENVIRONMENTAL DAMAG
98-60-001 WATER LEAK DETECTION AND IDENTIFICATION
Body Electrical System (20)
12-BE-005 CLEARING DIAGNOSTIC CODE(S) FROM THE BLUE LINK SYSTEM
12-BE-004 BLUE LINK TELEMATICS UNIT (TMU) POP UP MESSAGE DIAGNOSTIC
12-BE-003 CONFIRMATION PROCEDURES AFTER REPLACEMENT OF BLUE LINK TELEMATICS UNI
11-BE-015 NAVIGATION TOUCH SCREEN RECALIBRATION
11-BE-013 ENGINE CONTROL UNIT (ECU) REPLACEMENT AND TESTING PROCEDURE
11-BE-010 CLEARING DIAGNOSTIC CODE(S) FROM BLUE LINK SYSTEM
10-BE-010 BLUETOOTH PHONEBOOK DOWNLOAD INTERCHANGES FIRST AND LAST NAME FIELDS
09-BE-023 STOP LAMP Z01 DIODE INSPECTION PROCEDURE
09-BE-009 ACTIVE HEADREST RESET PROCEDURE
08-BE-008 GENESIS - 1 - KEY CUTTING PROCEDURE AND 2 - SMART KEY PROGRAMMING
08-BE-012 PROGRAMMING HOMELINK MIRROR TO GARAGE DOOR RECEIVERS WITH ROLLING COD
08-BE-007 RESETTING GENESIS ELECTRONIC COMPONENTS AFTER SERVICING VEHICLE BATTE
08-BE-004 DIAGNOSIS VOLTAGE DROP
07-90-005 GARMIN NUVI PORTABLE NAVIGATION TROUBLE SHOOTING AND WARRANTY INSTRUCT
05-90-001 RADIO FREQUENCY DETECTOR SERVICE TOOL
03-90-016 Wire Harness Repair Kit
03-90-001 Clicking Noise From Radio Speakers Caused by Wireless Telephone Inter
02-90-005 Audio System Diagnostic Tips
01-90-011 Programming Hyundai Security Systems
01-00-001 Key Cutting Information
Brake System (7)
12-BR-001 ABS PUMP SELF-CHECK NOISE
10-SS-003 BRAKE FLUID PRECAUTIONS - ADDING OR CHANGING FLUID
10-BR-001 BRAKE SERVICE BEST PRACTICES RECOMMENDATIONS
09-BR-001-1 PARKING BRAKE SHOE REPLACEMENT KIT
09-BR-001 PARKING BRAKE SHOE REPLACEMENT KIT
07-50-003 BRAKE CLEANER - VOC COMPLIANT
04-50-010 DRUM BRAKE WHEEL CYLINDER BRAKE FLUID LEAKAGE INSPECTION PROCEDURE
Chassis (3)
12-SS-001-1 ALIGNMENT SPECIFICATIONS - 2012MY
12-SS-001 ALIGNMENT SPECIFICATIONS - 2012MY
11-SS-006 ALIGNMENT SPECIFICATIONS - 2012MY
Engine Electrical System (4)
10-EE-003 GR8 DIAGNOSTIC BATTERY TESTER/CHARGER TOOL & NEW BATTERY WARRANTY POL
08-EE-001 DEALER BATTERY MAINTENANCE FOR IN-STOCK VEHICLES AND PRE-DELIVERY
05-36-011 BATTERY MAINTENANCE, DIAGNOSTIC, CHARGING, REPLACEMENT AND WARRANTY IN
02-36-017 Spark Plug Parts Information
Engine Mechanical System (12)
10-EM-003 ENGINE OIL PUMP REPLACEMENT GUIDELINES DURING ENGINE REPLACEMENT
10-EM-002 HYUNDAI GRAY RTV SILICONE GASKET MAKER UPDATED PRODUCT INFORMATION
09-EM-006 GUIDELINES AND TORQUE SPECIFICATIONS OF ENGINE FASTENERS USING THE TO
09-EM-002 CVVT OIL CONTROL VALVE INSPECTION
09-EM-001 UNNECESSARY ENGINE FLUSH SERVICES
08-EM-004 REMANUFACTURED ENGINE PROGRAM
05-20-005 FUEL MILEAGE CALCULATION
05-20-004 SULFUR ODOR FROM EXHAUST
05-20-002 USE OF AFTERMARKET ENGINE OIL FILTERS CAUSING ENGINE KNOCKING NOISE
04-20-001 Engine Oil Filter Information
03-20-001 Oil Consumption Test Procedure
02-20-002 Cylinder Head, Connecting Rod and Main Bearing Bolt Reuse Guidelines a
Fuel System (6)
10-FL-014 HYUNDAI FUEL SYSTEM CLEANER PLUS RECOMMENDATION AND FUEL QUALITY INFO
09-FL-006 EVAPORATIVE EMISSION SYSTEM DIAGNOSTIC INFORMATION
08-FL-008 USE OF E85 BLENDED ETHANOL FUEL
04-36-019 2005MY ECM AND PCM VIN WRITING DURING CONTROL MODULE REPLACEMENT
02-30-001 Enhanced Evaporative Emission Control Diagnosis and Repair for P0442,
10-FL-013 TESTING FUEL QUALITY TO DIAGNOSE ENGINE STARTABILITY / HESITATION / D
General Information (14)
11-GI-007 RECREATIONAL TOWING REQUIREMENTS
10-GI-001 LABEL REQUIREMENTS FOR VEHICLE LOADING TO COMPLY WITH FMVSS 110
09-GI-001-1 AI BLUECONNECT BLUETOOTH ACCESSORY TROUBLESHOOTING GUIDE
09-GI-001 AI BLUECONNECT BLUETOOTH ACCESSORY TROUBLESHOOTING GUIDE
08-GI-003 RECREATIONAL TOWING REQUIREMENTS
08-GI-002 1986-2009 MY VIN DECODER
08-01-003 RECEIVER HITCH MOUNTED BICYCLE RACK (CAMPAIGN 081)
07-00-002 DISPOSAL/RECYCLING OF MERCURY CONTAINING MATERIALS
07-00-001 DISPOSAL/HANDLING OF PERCHLORATE CONTAINING MATERIALS - CALIFORNIA LEG
03-50-001 Tire Company Assistance
02-00-002 VIN Decoder
01-00-003 Updating The Hi-Scan Using a PC With Internet Access
01-00-002 VIN Decoder
00-00-001 HI-SCAN PRO SOFTWARE UPDATE PROCEDURE
Heating, Ventilation and Air Conditioning (1)
07-97-003 A/C COMPRESSOR FIELD COIL SPECIFICATION
Manual Transmission (2)
05-40-007-1 MANUAL TRANSAXLE GEAR LUBRICANT
02-40-021 75W/90 (API GL-4) Manual Transaxle Oil
Restraints (7)
05-90-009 SIDE IMPACT AIR BAGS
05-09-001 SRS SPECIAL TOOL KIT (J-44611-KIT-A) COMPONENT DELETION
04-90-002 Supplemental Restraint System (SRS) Repair After Collision
02-90-013 Ordering Replacement Parts for SRS II Tester Kit (J-44611-KIT)
02-00-001 Service Precautions For SRS Equipped Vehicles
01-90-013 Supplemental Restraint System (SRS) Repair After Collision
01-90-012 Side Impact Air Bags
Steering System (2)
08-ST-001 SERVICE TIP - POWER STEERING OIL PUMP WHINE NOISE
07-50-002 PSF-4, HYUNDAI GENUINE POWER STEERING FLUID
Suspension System (19)
10-SS-005 DISC BRAKE MACHINING RECOMMENDATIONS
10-SS-002 TPMS (TIRE PRESSURE MONITORING SYSTEM) GENERAL INFORMATION
08-SS-002 TPMS LAMP "ON" AT COLD - Revised See 08-SS-002-1
08-SS-008 ALIGNMENT SPECIFICATIONS - 2009 MY PASSENGER VEHICLES
08-SS-005 CAUTIONS DURING TPMS (TIRE PRESSURE MONITORING SYSTEM) WHEEL SENSOR S
08-SS-004 DIAGNOSIS AND CORRECTION OF VEHICLE PULL
08-SS-003 TIRE AND WHEEL VIBRATION AND RADIAL FORCE VARIATION
07-50-004 TPMS (TIRE PRESSURE MONITORING SYSTEM) WARNING LAMP - ELECTROMAGNETIC
07-50-001 TPMS (TIRE PRESSURE MONITORING SYSTEM) TIRE PRESSURE WARNING LAMP "ON"
06-50-013 TIRE AND WHEEL VIBRATION AND RADIAL FORCE VARIATION
06-50-010-1 TIRE INFLATION PRESSURE - PDI INSPECTION
06-50-010 TIRE INFLATION PRESSURE - PDI INSPECTION
05-50-012 DIAGNOSIS AND CORRECTION OF VEHICLE PULL
04-50-005 WHEEL LUG NUT TORQUE - SERVICE TIP
03-50-003 Wheel Lug Nut Torque - Service Tip
03-50-002 Wheel Alignment Specifications
02-50-005 Alignment Specifications
02-50-004 Tire Company Assistance
01-50-008 Tire and Wheel Vibration and Radial Force Variation
OBD-II
Drive Cycle (All Except Delphi EMS)
Drive Cycle (Delphi EMS Only)
I've tried to get on to the web site, but it appears that I have to be a service tech. How did you get on??
I tried to get on to the web site, but it appears that you have to be a service tech to get the technical info. How did you get on to download the info.
There is a SIGN UP button. I just clicked and I joined. Not sure why I was special if others can't do this. Sorry.
I accessed the Service Site 3 years ago. Great information, drawings, tech bullitins and your personal VIN history all @ NO charge! Fast forward to the present: It now costs $300 a year for information! Not real pleased with Hyundai Service Site now!
I was a member back in 2009, but very rarely used the site. Just tried to sign on again, but userid not found. I guess they deleted me. Tried to create new account, but now they want to charge me.... NAH!! Really? C'mon Hyundai.
Yes, really. This has been discussed in several threads on this forum over the last 3-4 weeks. They gave about two weeks notice (when logging on) before switching to a fee based access.
Sorry :( I missed all the other threads. I obviously never needed the service when it was free. I think 2009 was the last time I logged on to it. Thanks for the update !
I tried the same thing, and it cost and it is a hassle. Hyundai should allow the car owners access to the site. This is not good policy on their behalf.
Well they did set a precedent by allowing people to access for free but I can totally see their point from a business perspective. No service manuals for consumers means more people coming into local dealers for service. $$$$$
Looks like someone from who has a Coupe downloaded the service manual then put in on skydrive: http://www.Genesis Coupe.com/engine/42892-complete-2-0-3-8-pdf-shop-manuals.html
Has anyone saved the sedan manual???
