Parking Brake > Electric Parking Brake
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1103 Ignition Signal Failure
C1241 Force Sensor Failure
C1242 Force Sensor Not Calibrated
C1262 Temperature Sensor Failure
C1270 Temperature / Overload
C1501 Switch Failure
C1604 ECU Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN signal error ECM (Check ECM)
C1616 CAN Bus off
C1625 CAN Time-out ABS/ESC(ESP)
C1628 CAN Timeout - Cluster
C1642 CAN signal error ESC(ESP)
C1646 CAN signal error TCU
C1656 CAN signal error Cluster
C2202 Latching Failure / Mechanics
C2402 Motor Electrical
Steering > Electric Hydraulic Power Steering
C1260 Steering Angle Sensor Circuit-Signal
C1603 ECU thermal protection
C1617 EMS Invalid Engine Speed
C1622 EMS invalid vehicle speed
C1623 CAN Time-out Steering Angle Sensor
C2400 Motor Fault - Motor Not Running
C2413 Motor current fail (current over)
C2420 Motor temperature sensor high input
C2421 Motor Temperature Sensor Low Input
Tire Pressure Monitoring > Tire Pressure Monitoring System
C1121 Front Left Sensor Battery Voltage Low
C1122 Front Right Sensor Battery Voltage Low
C1123 Rear Left Sensor Battery Voltage Low
C1124 Rear Right Sensor Battery Voltage Low
C1126 TPMS ECU Battery Voltage Low
C1127 TPMS ECU Battery Voltage High
C1212 First Speed Input Fault
C1240 Second Speed Input Fault
C1300 LF/RF External Interference Failure
C1306 RF Internal Interference Failure
C1312 Front Left Sensor RF Channel Failure
C1313 Front Right Sensor RF Channel Failure
C1314 Rear Left Sensor RF Channel Failure
C1315 Rear Right Sensor RF Channel Failure
C1322 Front Left Sensor Over Temperature
C1323 Front Right Sensor Over Temperature
C1324 Rear Left Sensor Over Temperature
C1325 Rear Right Sensor Over Temperature
C1332 Front Left Sensor Fault
C1333 Front Right Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1345 Front Low Frequency Initiator Channel Failure
C1346 Rear Low Frequency Initiator Channel Failure
C1660 Receiver Radio Frequency Circuit Failure
C1661 Receiver EEPROM Failure
C1664 Initiator/LF/RF Circuit Failure Not Affecting RSSI Level(High Line Only)
C1665 Initiator supply circuit short to ground
C1666 Initiator supply circuit short to battery
C1668 Internal failure detection
C2510 TREAD LAMP open/short circuit
C2512 Front Left LAMP open/short circuit
C2513 Front Right LAMP open/short circuit
C2514 Rear Left LAMP open/short circuit
C2515 Rear Right LAMP open/short circuit
Transmission > A8TR1
P0601 Internal Control Module Memory Check Sum Error
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0711 Transmission Fluid Temperature Sensor 'A' Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor 'A' Circuit Low Input
P0713 Transmission Fluid Temperature Sensor 'A' Circuit High Input
P0717 Input/Turbine Speed Sensor 'A' Circuit No Signal
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0729 Gear 6 Incorrect Ratio
P0730 Gear 8 Incorrect Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0743 Torque Converter Clutch Circuit Electrical
P0748 Pressure Control Solenoid Valve(VFS) 'A' Electrical
P0753 Shift Control Solenoid Valve 'A' Electical (UD/B)
P0758 Shift Control Solenoid Valve 'B' Electrical (2-6/B)
P075A ON/OFF Solenoid
P0763 Shift Control Solenoid Valve 'C' Electrical (35R/C)
P0768 Shift Control Solenoid Valve 'D' Electrical (OD/C)
P076F Gear 7 Incorrect Ratio
P0773 Shift Control Solenoid Valve 'E' Electrical (SS-A)
P0791 Middle Speed Sensor Circuit No Signal
P0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
P0880 TCM Power Signal Error Open/Short (GND)
P0881 TCM Power Input Signal Range/Performance
P2709 Shift Control Solenoid Valve 'F' Electrical (SS-B)
U0001 High Speed CAN Communication Bus off
U0100 Lost Communication With ECM/PCM 'A'
TSB
Automatic Transaxle (57)
12-AT-011 AUTOMATIC TRANSAXLE HARSH AND/OR DELAYED SHIFT – GDS ANALYSIS
12-AT-010 AUTOMATIC TRANSMISSION OIL PRESSURE DATA TRANSFER
12-AT-006-1 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
12-AT-006 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
12-AT-005 AUTOMATIC TRANSMISSION STALL TEST PROCEDURE
12-AT-004-1 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
12-AT-004 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
12-AT-001 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
11-AT-008-1 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VAL
11-AT-020 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
11-AT-017-1 AUTOMATIC TRANSMISSION SOLENOID& SENSOR DTC P0741, P0743, P0748, P0
11-AT-017 AUTOMATIC TRANSMISSION SOLENOID& SENSOR DTC P0741, P0743, P0748, P075
11-AT-016-1 ATM OIL TEMPERATURE SENSOR DTC P0711, P0712 & P0713
11-AT-016 ATM OIL TEMPERATURE SENSOR DTC P0711, P0712 & P0713
11-AT-015-1 ATM INPUT, MIDDLE AND OUTPUT SPEED SENSOR DTC P0717, P0721, P0722 &
11-AT-015 ATM INPUT, MIDDLE AND OUTPUT SPEED SENSOR DTC P0717, P0721, P0722 & P
11-AT-013 AUTOMATIC TRANSMISSION OIL PRESSURE DATA TRANSFER
11-AT-012 8-SPEED AUTOMATIC TRANSMISSION FLUID LEVEL
11-AT-008 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
11-AT-006 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
11-AT-005 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
10-AT-011 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
10-AT-008 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
10-AT-002 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
09-AT-008 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
09-AT-007 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
09-AT-006 HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE
09-AT-002-1 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VAL
09-AT-002 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
09-AT-001 GENESIS COUPE V6 AND GENESIS V8 AUTOMATIC TRANSMISSION FLUID LEVEL
08-AT-013 NEUTRAL START SWITCH ADJUSTMENT 2009~ GENESIS 3.8L V6
08-AT-010 Revised. See 09-AT-007
08-AT-008 GENESIS V8 AUTOMATIC TRANSAXLE FLUID LEVEL
08-AT-007 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUE
07-40-011 AUTOMATIC TRANSAXLE OIL COOLER FLUSHING
07-40-007 Revised. See 09-AT-008
07-40-006 REMANUFACTURED AUTOMATIC TRANSAXLE (ATM) PROGRAM
06-40-016 AUTOMATIC TRANSAXLE FLUID LEVEL
06-40-014 AUTOMATIC TRANSAXLE STALL TEST PROCEDURE
06-40-012 OIL LEAK FROM DIFFERENTIAL OIL SEALS
06-40-005 AUTOMATIC TRANSAXLE CONTROL MODULE - RESET AND RELEARN ADAPTIVE VALUES
06-40-002 AUTOMATIC TRANSAXLE OIL LEAK BEHIND TORQUE CONVERTER
05-40-016 AUTOMATIC TRANSAXLE - NO MOVEMENT IN DRIVE OR REVERSE GEAR
05-40-012 AUTOMATIC TRANSAXLE INSTALLATION PROCEDURE TO PREVENT DAMAGE TO OIL PU
05-40-005 UPDATED ATM DIAGNOSIS WORKSHEET
04-40-021 AUTOMATIC TRANSAXLE TORQUE CONVERTER INSPECTION
04-40-016 AUTOMATIC TRANSAXLE DIAGNOSTIC TROUBLE CODE P0711, P0712 AND P0713
04-40-009-1 AUTOMATIC TRANSAXLE DIFFERENTIAL OIL SEAL INSTALLER
03-40-013 Automatic Transaxle Range Switch Diagnostic Trouble Codes P0705, P0707
03-40-005 Automatic Transaxle Diagnostic Trouble Codes P0731, P0732, P0733, P073
03-40-003 Automatic Transaxle Control Module Adaptive Learning
02-40-018-1 Automatic Transaxle - Cruise Control Operation
02-40-018 Automatic Transaxle - Cruise Control Operation
02-40-007 Automatic Transaxle Torque Converter Clutch Diagnosis
01-40-021 Oil Leak Behind Torque Converter
01-40-004 Remanufactured Automatic Transaxle (ATM) Program
01-40-002 Automatic Transaxle Control Module Adaptive Learning
Body (Interior and Exterior) (11)
09-BD-011 SUNROOF CREAK / TICK NOISE REPAIR
09-BD-010 BODY DIMENSION INFORMATION
09-BD-003 ALUMINUM
WHEEL CLEANING AND MAINTENANCE
07-99-001 CLOUDED PAINT CORRECTIVE PROCEDURE
07-90-002 PROGRAMMING HOMELINK MIRROR TO GARAGE DOOR RECEIVERS WITH ROLLING CODE
05-80-003 SEAT INSTALLATION PROCEDURES
05-00-001 RECREATIONAL TOWING REQUIREMENTS
04-80-002 ROUND MARKS ON THE INSIDE GLASS SURFACES
00-99-001 CLOUDED PAINT CORRECTIVE PROCEDURE
99-99-001 PAINT EXAMINATION, REPAIR AND PREVENTIVE STEPS FOR ENVIRONMENTAL DAMAG
98-60-001 WATER LEAK DETECTION AND IDENTIFICATION
Body Electrical System (20)
12-BE-005 CLEARING DIAGNOSTIC CODE(S) FROM THE BLUE LINK SYSTEM
12-BE-004 BLUE LINK TELEMATICS UNIT (TMU) POP UP MESSAGE DIAGNOSTIC
12-BE-003 CONFIRMATION PROCEDURES AFTER REPLACEMENT OF BLUE LINK TELEMATICS UNI
11-BE-015 NAVIGATION TOUCH SCREEN RECALIBRATION
11-BE-013 ENGINE CONTROL UNIT (ECU) REPLACEMENT AND TESTING PROCEDURE
11-BE-010 CLEARING DIAGNOSTIC CODE(S) FROM BLUE LINK SYSTEM
10-BE-010 BLUETOOTH PHONEBOOK DOWNLOAD INTERCHANGES FIRST AND LAST NAME FIELDS
09-BE-023 STOP LAMP Z01 DIODE INSPECTION PROCEDURE
09-BE-009 ACTIVE HEADREST RESET PROCEDURE
08-BE-008 GENESIS - 1 - KEY CUTTING PROCEDURE AND 2 - SMART KEY PROGRAMMING
08-BE-012 PROGRAMMING HOMELINK MIRROR TO GARAGE DOOR RECEIVERS WITH ROLLING COD
08-BE-007 RESETTING GENESIS ELECTRONIC COMPONENTS AFTER SERVICING VEHICLE BATTE
08-BE-004 DIAGNOSIS VOLTAGE DROP
07-90-005 GARMIN NUVI PORTABLE NAVIGATION TROUBLE SHOOTING AND WARRANTY INSTRUCT
05-90-001 RADIO FREQUENCY DETECTOR SERVICE TOOL
03-90-016 Wire Harness Repair Kit
03-90-001 Clicking Noise From Radio Speakers Caused by Wireless Telephone Inter
02-90-005 Audio System Diagnostic Tips
01-90-011 Programming Hyundai Security Systems
01-00-001 Key Cutting Information
Brake System (7)
12-BR-001 ABS PUMP SELF-CHECK NOISE
10-SS-003 BRAKE FLUID PRECAUTIONS - ADDING OR CHANGING FLUID
10-BR-001 BRAKE SERVICE BEST PRACTICES RECOMMENDATIONS
09-BR-001-1 PARKING BRAKE SHOE REPLACEMENT KIT
09-BR-001 PARKING BRAKE SHOE REPLACEMENT KIT
07-50-003 BRAKE CLEANER - VOC COMPLIANT
04-50-010 DRUM BRAKE
WHEEL CYLINDER BRAKE FLUID LEAKAGE INSPECTION PROCEDURE
Chassis (3)
12-SS-001-1 ALIGNMENT SPECIFICATIONS - 2012MY
12-SS-001 ALIGNMENT SPECIFICATIONS - 2012MY
11-SS-006 ALIGNMENT SPECIFICATIONS - 2012MY
Engine Electrical System (4)
10-EE-003 GR8 DIAGNOSTIC BATTERY TESTER/CHARGER TOOL & NEW BATTERY WARRANTY POL
08-EE-001 DEALER BATTERY MAINTENANCE FOR IN-STOCK VEHICLES AND PRE-DELIVERY
05-36-011 BATTERY MAINTENANCE, DIAGNOSTIC, CHARGING, REPLACEMENT AND WARRANTY IN
02-36-017
Spark Plug Parts Information
Engine Mechanical System (12)
10-EM-003 ENGINE OIL PUMP REPLACEMENT GUIDELINES DURING ENGINE REPLACEMENT
10-EM-002 HYUNDAI GRAY RTV SILICONE GASKET MAKER UPDATED PRODUCT INFORMATION
09-EM-006 GUIDELINES AND TORQUE SPECIFICATIONS OF ENGINE FASTENERS USING THE TO
09-EM-002 CVVT OIL CONTROL VALVE INSPECTION
09-EM-001 UNNECESSARY ENGINE FLUSH SERVICES
08-EM-004 REMANUFACTURED ENGINE PROGRAM
05-20-005 FUEL MILEAGE CALCULATION
05-20-004 SULFUR ODOR FROM EXHAUST
05-20-002 USE OF
AFTERMARKET ENGINE OIL FILTERS CAUSING ENGINE KNOCKING NOISE
04-20-001 Engine Oil Filter Information
03-20-001 Oil Consumption Test Procedure
02-20-002 Cylinder Head, Connecting Rod and Main Bearing Bolt Reuse Guidelines a
Fuel System (6)
10-FL-014 HYUNDAI FUEL SYSTEM CLEANER PLUS RECOMMENDATION AND FUEL QUALITY INFO
09-FL-006 EVAPORATIVE EMISSION SYSTEM DIAGNOSTIC INFORMATION
08-FL-008 USE OF E85 BLENDED ETHANOL FUEL
04-36-019 2005MY ECM AND PCM
VIN WRITING DURING CONTROL MODULE REPLACEMENT
02-30-001 Enhanced Evaporative Emission Control Diagnosis and Repair for P0442,
10-FL-013 TESTING FUEL QUALITY TO DIAGNOSE ENGINE STARTABILITY / HESITATION / D
General Information (14)
11-GI-007 RECREATIONAL TOWING REQUIREMENTS
10-GI-001 LABEL REQUIREMENTS FOR VEHICLE LOADING TO COMPLY WITH FMVSS 110
09-GI-001-1 AI BLUECONNECT BLUETOOTH ACCESSORY TROUBLESHOOTING GUIDE
09-GI-001 AI BLUECONNECT BLUETOOTH ACCESSORY TROUBLESHOOTING GUIDE
08-GI-003 RECREATIONAL TOWING REQUIREMENTS
08-GI-002 1986-2009 MY
VIN DECODER
08-01-003 RECEIVER HITCH MOUNTED BICYCLE RACK (CAMPAIGN 081)
07-00-002 DISPOSAL/RECYCLING OF MERCURY CONTAINING MATERIALS
07-00-001 DISPOSAL/HANDLING OF PERCHLORATE CONTAINING MATERIALS - CALIFORNIA LEG
03-50-001 Tire Company Assistance
02-00-002
VIN Decoder
01-00-003 Updating The Hi-Scan Using a PC With Internet Access
01-00-002
VIN Decoder
00-00-001 HI-SCAN PRO SOFTWARE UPDATE PROCEDURE
Heating, Ventilation and Air Conditioning (1)
07-97-003 A/C COMPRESSOR FIELD COIL SPECIFICATION
Manual Transmission (2)
05-40-007-1 MANUAL TRANSAXLE GEAR LUBRICANT
02-40-021 75W/90 (API GL-4) Manual Transaxle Oil
Restraints (7)
05-90-009 SIDE IMPACT AIR BAGS
05-09-001 SRS SPECIAL TOOL KIT (J-44611-KIT-A) COMPONENT DELETION
04-90-002 Supplemental Restraint System (SRS) Repair After Collision
02-90-013 Ordering Replacement Parts for SRS II Tester Kit (J-44611-KIT)
02-00-001 Service Precautions For SRS Equipped Vehicles
01-90-013 Supplemental Restraint System (SRS) Repair After Collision
01-90-012 Side Impact Air Bags
Steering System (2)
08-ST-001 SERVICE TIP - POWER STEERING OIL PUMP WHINE NOISE
07-50-002 PSF-4, HYUNDAI GENUINE POWER STEERING FLUID
Suspension System (19)
10-SS-005 DISC BRAKE MACHINING RECOMMENDATIONS
10-SS-002 TPMS (TIRE PRESSURE MONITORING SYSTEM) GENERAL INFORMATION
08-SS-002 TPMS LAMP "ON" AT COLD - Revised See 08-SS-002-1
08-SS-008 ALIGNMENT SPECIFICATIONS - 2009 MY PASSENGER VEHICLES
08-SS-005 CAUTIONS DURING TPMS (TIRE PRESSURE MONITORING SYSTEM)
WHEEL SENSOR S
08-SS-004 DIAGNOSIS AND CORRECTION OF VEHICLE PULL
08-SS-003 TIRE AND
WHEEL VIBRATION AND RADIAL FORCE VARIATION
07-50-004 TPMS (TIRE PRESSURE MONITORING SYSTEM) WARNING LAMP - ELECTROMAGNETIC
07-50-001 TPMS (TIRE PRESSURE MONITORING SYSTEM) TIRE PRESSURE WARNING LAMP "ON"
06-50-013 TIRE AND
06-50-010-1 TIRE INFLATION PRESSURE - PDI INSPECTION
06-50-010 TIRE INFLATION PRESSURE - PDI INSPECTION
05-50-012 DIAGNOSIS AND CORRECTION OF VEHICLE PULL
04-50-005
WHEEL LUG NUT TORQUE - SERVICE TIP
03-50-003
Wheel Lug Nut Torque - Service Tip
03-50-002
Wheel Alignment Specifications
02-50-005 Alignment Specifications
02-50-004 Tire Company Assistance
01-50-008 Tire and
Wheel Vibration and Radial Force Variation
OBD-II
Drive Cycle (All Except Delphi EMS)
Drive Cycle (Delphi EMS Only)
