2015 Genesis 3.8 - Standing water in my backseat floorboard??????
Tbolmstead
Houston, Texas
This is the 4th time I have had my car into the dealer for standing water in my backseat floorboard behind the drivers seat. There are no water stains in the roof lining, etc. Each time I have had it in after it gets wet, which is always after we have had some rain - I have taken it in right away. It is in the shop now - they have torn apart the interior and are getting ready to test AGAIN. They cannot find the source of the leak.
Very frstrated and just want to know if anyone else has had this problem!!!!!!!!!!!!!
Thanks
check the rear door sound/weatherproofing seal. that was a common issue on old BMWs.
On my previously owned Cadillac CTS, they were notorious for the drains running from the sunroof tracks becoming clogged with debris.
Had to run fishing line down through it to make sure it drained onto the ground. Otherwise the water would find its way onto the
back floorboard.
Don't know if the Genesis has a similar design.
Could be drain in front of rear wheel well. I happen once year ago and leaves etc ha made their way to the drain and stopped it up. Sisnce then I have tried to keep leaves and pine needles cleaned out under trunk lid and under the hood. Hope they find the source.
