2015 Genesis flasher module
larrymg1
Lexington South Carolina
Genesis G80 Sport
Please advise what type, if any, flasher module is on the 2015 Genesis. Is it replaceable? Location?
Thanks
I'd like to know the same thing. Did you ever find an answer? If you replace the 1157 turn signal bulbs with LEDs, it would be easiest to just swap out the flasher.
Doc 817
Since my earlier reply I have verified that the flasher unit is not replaceable. Additionally. I have attempted to use LEDS from two suppliers and neither worked correctly. Still had hyper flashing. Awaiting follow-up from one supplier on their engineers coming up with a solution.
Yes I have tried resistors from both manufacturers, including Dynamics with no success.
You may need two resistors in parallel on each side. That's what I had to do for my 3.8 Track Coupe with DD switchbacks. For some reason (I'm not sure why), that was unique to the Track trim.
Hyper flashing also is not a bad thing - gets more attention & visibility.
