I have the "SYNC" button activated. The passenger side vents always blow "ice cold" but driver's side will only blow "cool" and I've tried it both ways; with "SYNC" on and "SYNC" off.Turn of HVAC "SYNC" button and let passenger chose they temperature. That's all you can do.
FYI, if the passenger turns their temp knob, sync automatically shuts off.
Probably, the driver's side air temperature door actuator is failing.I have the "SYNC" button activated. The passenger side vents always blow "ice cold" but driver's side will only blow "cool" and I've tried it both ways; with "SYNC" on and "SYNC" off.
NC". This used to happen only occasionally but now it's all the time.
Maybe it forces the actuator door to move in a greater motion and it frees it up?As to why this works
Maybe. It beats having "reboot" the car like I used to do...Maybe it forces the actuator door to move in a greater motion and it frees it up?
How did you reboot the car? Just disconnecting the battery for a few minutes? I have the same problem with the driver's side chest height vents blowing warm.Maybe. It beats having "reboot" the car like I used to do...
Turn car off, then restart... guess it unsticks the vent flaps when it recycles.How did you reboot the car? Just disconnecting the battery for a few minutes? I have the same problem with the driver's side chest height vents blowing warm.
Didn't help unfortunately. Also disconnected the battery and reconnected - that didn't help either. I'll try a last-ditch attempt but I bet it's a faulty blend door actuator or valve and they'll have to take off the whole freaking dash to replace a $70 part.Turn car off, then restart... guess it unsticks the vent flaps when it recycles.
