2016 Genesis Sedan Custom Audio Build
MCCSolutions
Figured I'd split off my own little custom audio build.
2 old dusty 15 year old Visonik comp v12s (800w rms) DVC wired in 4ohm on Sharkamp 3500.1 Monoblock(I've had this combo since 2015 and they'll take every watt you throw at em)
Red and black theme. (Mostly black lol)
Terminal tap 0ga, inline fuse, with display, 8ga to speaker. NVX XPLOC2 300W Super Low Distortion 2-Channel Adjustable Line Output Converter with Hifonics BXIPRO1.0 Digital Bass Equalizer Sub Enhancement Processor. Vintage gold plated Visonik RCA.
Box is 34"x29.5"x16" OD
About as big as you can go without trimming the trunk. Its also just small enough to be able to pull the box out to get to spare etc. Leaves room on left and right for stuff. The top corners are cross cut 45° for 8" to ease fit.
3x4" plywood braced with 2x3"s and liquid nailed to death :)
20200718_115945.webp20200718_101457.webp20200718_101308.webp20200718_120217.webp20200718_100240.webp20200718_095312.webp
Some pics from along the way.
18"x8"×1/2" Acrylic window with genny logo, for the bandpass section, rgb lit
More box info:
Hybrid 4th order bandpass. Non chambered, rear is dual prted in the center, tuned @60hz. Not sure what the seal section will do but given the volume it should get 18~30hz
Box is done(ish). I'm going to have a full acrylic front window machined and I have to get longer bolts. Got it in the car to test tomorrow and tune b4 I button it up the trunk20200719_204839.webp20200719_214043.webp20200719_200235.webp20200719_212338.webp.
VERY VERY nice!!!
