AC Issues in Rain
This thread is two years old, but I'm now experiencing this issue. North Texas had a lot of rain today, it was mid 80's in the sun and low 70's in the rain cooled areas. Near 100% humidity.
After driving about 30-40 minutes into a 1 hour drive on the highway I noticed the interior was not as cool, and airflow was restricted. I recognized the problem right away, having read this thread back in 2023.
It happened on the return trip, too. If I turned the system off and waited about 5 minutes and turned it back on, it would blow cold air right off, and worked well for another five minutes, then freeze up again.
Guess I need to go in and get my refrigerant removed and reloaded. I just ordered a new cabin filter as well.
Coincidentally, I've noticed a moldy smell when the AC first comes on, at start. A couple weeks ago I removed that thermistor and sprayed a can of auto coil cleaner (Nextzett Klima Cleaner Pro) in there. It drained out the drain hose quickly, as expected. I re-inserted the thermistor and locked out back down. I suppose I could have damaged the thermistor, but I don't think I did.
This really is a common issue in these cars.
Certainly sounds like a frozen evap coil. The temperature drop and high humidity did not help either. Hope it is simple solution.
Newer G80 models have an evaporator drying function that runs 30 minutes after you shut off the car. I am sure that helps with musty smells and mold growing inside the AC system. Not going to help with the freezing problem, however.
