- Mar 25, 2008
- Location
- Florida
- Genesis Model Year
- 2015
Mando ECS10 Suspension Control
Plug ‘n play device for the Kia Stinger, Genesis G70 and Genesis G80 with an Electronically Controlled Suspension. Stock damping force is set at only 60% of what the suspension can use. This module allows you to use 100% – even on “uneven” roads. It automatically detects the damping pressure.
kdmwarehouse.com
If your GV60 came with the ECS (electronically controlled suspension) system - which is made by Mando - you can further adjust your suspension exactly the way you want it with the Mando ECS-10 Suspension Control Unit.
"I just installed the Mando controller on my G70. I just ran the default Sport and Comfort mode and I'm amazed at how good it is. The sport setting feels much "sportier" then the stock setting, yet also seems more comfortable. I can't understand why the car wasn't programmed this way from the factory." (review from the Stinger forum)
If your GV60 does not already have an electronically controlled suspension (ECS) system, the Mando ECS10 unit will not work with your vehicle.
Stock damping force is set at only 60% of what the suspension can use. This module allows you to use 100% – even on “uneven” roads. It automatically detects the damping pressure. Damping force can be adjusted according to your taste.
When set for comfort, the ride will be more comfortable than without the module. When sport mode is set, the ride will be firmer than possible without the module. When set to 100% firm, it becomes very firm.
