What year and model Genesis do you have?. ....I was searching for the bolt specs for weeks, I criss crossed the bolts when it came to tightening them & then went all the way around & checked them again, I have them snugged , so I will surely find out if they are snugged enough....
Wow.....it's been awhile but I'm about to do a transmission ATF drain ( my 2nd time doing it on this car ), ATF pan replacement , oil change , coolant flush & replace my alternator next month .....so it's time to start finding everything I need for this job.......still going to use Redline ATF as it has performed well for me so far......I'll post again once I have everything in front of me.......
....I see that they have metal ATF pans now with replaceable filters ......
ZF6HP26 Metal Oil Pan Replaces Plastic ZF6HP28 Automatic Transmission Fluid Filter Pan Kit 6HP26
Check out the deal on ZF6HP26 Metal Oil Pan Replaces Plastic ZF6HP28 Automatic Transmission Fluid Filter Pan Kit 6HP26 at Oregon Performance Transmissionoregonperformancetransmission.com
.....have to do my homework.....
......so I'm currently looking at this from that website...it's not stating if it's plastic or metal, though it looks plasticPart number is 0501 216 243. I got mine in a kit from FCP Euro that came with all new bolts and the ZF fluid.
BMW GA6HP26Z Automatic Transmission Oil Pan With Filter - ZF 24152333903
BMW GA6HP26Z Automatic Transmission Oil Pan With Filter - ZF 24152333903www.fcpeuro.com
