Backup sensor question ??
darrell
Marietta, GA
2010 Genesis 3.8 w/Tech package....
This morning my wife was backing the vehicle out of the garage and the backup sensor activated as it normally does. Indicating a close object to the left rear and center rear of the vehicle. The left rear indication is normal and is caused by the left side door frame of the garage opening. Once the vehicle passes the door frame the left indication goes away. The rear center sensor remained activated all the way out of the driveway until the gear shift was placed in drive.
Temp this morning was in the low 30's causing vapor and condensation smoke from exhaust. Is it possible the exhaust vapors are dense enough to activate the rear backup sensor?
Owned vehicle for almost 3 years and do not recall this issue in the past.
Oddly enough. I am having this problem with my front sensors! Other cars' exhaust fumes are setting it off. So yes, it is possible for that to happen.
So YOU'RE the guy riding my rear bumper!! :D
