Battery draw 2015 Genesis when sitting
It will take that CTEK charger about 20 hours to get from 10.8 to 13.2 on a 115ah battery. If you're taking longer you either have draw, bad battery or bad charger connection.
Not too good a report on Hyundai dealers being able to fix a car. They can do routine stuff, but give them a tough problem and they don't have either the training or the equipment.
I think my battery is dying too.
One day I did not drive at lunch time and had to jump start to get home after work.
Measured the battery voltage at home and it was 10.8v.
Bought a CTEK 7002 charger and charged the battery for two nights
It now measures 12.6v but not sure if the battery is good - the charger is on 2nd light after 24h of charging
Will see how it start tomorrow
Original battery? If so, getting near end of life. Your battery started dying the day it was installed.
that's actually not the issue. Todays techs are "trained" as parts changers, not troubleshooters. It is not cost effective to the tech or the dealership to troubleshoot issues, they rely on trouble codes and documented procedure to know what part to replace. Replacing the part is faster, cheaper, and easier than troubleshooting a repair that is not going to be paid for.
for Warranty work, Techs/Dealers get paid by the piece, the more vehicles they complete work on the more they get paid.
example, if the book labor for changing an alternator is 3 hours and the tech can do it in 2, he still gets paid for the book labor (the time in which the manufacturer says it should take to do the job). To troubleshoot means he has to use his time to find the issue, if it takes 6 hours to find a power drain and the book time to fix the issue is 30 minutes, he just lost 5.5 hours of pay. Techs (and dealerships) do not like to troubleshoot for this reason.
The manufacturer warranty does not reimburse for the time it takes to find the problem, only the time documented to replaced the part or fix the problem.
While some manufacturers/dealers might have a tech who is on salary and whos job it is to just troubleshoot issues, not all dealers employ this type of tech.
For warranty, simple easy work that presents a trouble code and a documented fix is all dealer techs today work on, digging around to find the issue is not what they are employed to do and most dealerships don't want to waste the time or money for a real troubleshooting tech, they are a premium paid tech (usually a salary of around $50K-$60K) that is a cap-x cost to a dealership.
now if you as the customer are out of warranty and subjected to the dealerships hourly rate, you will find they have no issue spending 5-6 hours trying to figure out your issue.
Have any auto store do a free battery load check.
Yes. In south CA Autozone does free battery checks as do other major parts stores
Yeah I already figured out my battery is dead. No exact fit replacement available in Costco/Walmart so I ordered this online Advance Auto Parts - Down for Maintenance
BTW. What's the easiest way to measure a battery draw when the battery is in the trunk? When the trunk lid is open it draws ~5A
Did you have the 25% off coupon? D5K3BX
check the draw from under the hood at the jumper cable connectors.
Not so sure you can check amp draw at the jumper connectors.......I think they are in parallel with the battery terminals; so amps headed to the car don't pass through the jumper connectors ??
Yes they emailed me a 25% discount after I added it to the cart but did not checkout for a while
When checking a current draw we're connecting to the battery in series, not in parallel
Checking the current in a parallel will simply short the battery, so theoretically we would see CCA amperage
Practically, no multi meter will handle that current and will most likely burn its fuse or burn itself
Ran into a problem when trying to undo the bolt holding the battery.
It simply slips and wont go out
I now suspect alternator is at fault.
What's the voltage reading on the battery when the car is on?
I read 12.66v (with a brand new battery) which is the same when it t is off.
With engine running (off idle, 1,500rpm) it should be at least 13.5v up to 14v.
I wonder why the Charging System Warning Light is not on then?
This is from the manual:
If this warning light comes on while the engine is running, the battery is not being charged. Immediately turn off all electrical accessories. Try not to use electrically operated controls, such as the power windows. Keep the engine running; starting the engine will quickly discharge the battery. If there is a malfunction with either the alternator or electrical charging system: 1.Drive carefully to the nearest safe location and stop your vehicle. 2.Turn the engine off and check the alternator drive belt for looseness or breakage. If the belt is adjusted properly, there may be a problem in the electrical charging system. In this case, have your vehicle inspected by an authorized HYUNDAI dealer.
You need to test under load. AC set to max cool, headlights on, etc
The ECU controls the alternator for maximum efficiency - getting battery voltage is usually normal unless under sustained load. It takes less fuel to recharge the battery vs running accessories off alternator and dragging the engine. This is why it's important to replace with OE spec aH ratings- less causes undesirable levels of discharge.
This was a common problem back when I bought my 2015 Genesis. It took a long time to sort it out for those with the problem. What it wound up being at that time was the hood switch was either defective or not making proper contact. I would at least check that out.
The battery is charging now.
Not sure what was the issue, but I disconnected the battery, charged it, then let it sit overnight, connected - and it works now.
The first time I installed it just after it has been charged, so probably had high voltage and the car decided that there's something wrong with it and did not charge it.
These new cars are sometimes too smart.
I wonder if disconnecting restarted/rebooted something. Or even made a better contact.
