- May 17, 2017
- Location
- Los Angeles
- Genesis Model Year
- 2025
- Genesis GV80
works at any speed above 0, doesn't work if you are stopped. I have seen it highlight when accelerating from a stop light. I believe however it requires the object in the blind spot to also be moving.
This may be true on your G80 but I would be surprised if it were different from my G90. My manual says
The system will activate when:
1. The system is on.
2. The vehicle speed is above about
20 mph (30 km/h).
3. An oncoming vehicle is detected
in the blind spot area.
• The initial warning alert time for the
Lane Change Assist can be adjust-
ed. Go to the 'User Settings →
Driving Assist and select Lane
Change Assist' on the LCD display.
You may select between the two
stages you prefer.
- Normal/Late
Note that if your vehicle is travel-
ing much faster than the vehicles
around you, the warning will not occur.
Personally I have found the system to be 100% reliable thus far. I have never had a false positive or a false negative. Although I am sure anything is possible. Once in 18 months I have accidentally turned off the system (or the system turned itself off).
