10genesis
Can anyone give me some help as to how to remove the two lenses on the center dome lights, I want to changeout to LED bulbs on my 10 Genny 4.6
Thanks
Thanks
I have a 2009 Genesis 3.8 sedan and happen to come across your picture of dome light in my case the rear dome light. Would like to see the last picture clearer if possible and what led's did you to attach to this.Still a little confused on set-up..althought it was quite easy for me, changing out the LEDs in the dome lights its a bit of a process most people dont want to endeavor. it requires desoldering/soldering and extensive disassembly of the housing. regular LEDs will not plug and play into the housing because Hyundai uses a proprietary LED that you will not find anywhere else. i suggest using an LED board with a bunch of LEDS on it (see link at the bottom).
inside the sunglass holder, there are 2 phillips screws holding the housing to the headliner, unscrew those and disconnect the connectors for the lights and the sunroof. the housing should come right out.
use a small flathead screw driver or nylon pry tool to pop out the 2 clear lenses.
Now use a small flathead again to pop out the 2 (1 for each led) plastic pieces/light director things.
there are some screws inside, remove those.
on the backside of the housing there is a plastic cover/shroud covering the circuitboard/connections.
(im not sure which screws inside to remove, im doing this post off of memory)
you need to desolder the 3 wires going to each led circuit and solder your new lights onto them. heres a thread i made a while ago explaining this..... http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=9052
if you still need help feel free to let me knowgood luck
Simple fix go to the junk yard found the same one different color interior and change them from there. You can't buy them unfortunately. But mine is working fine now. Spent $35.00Can anyone give me some help as to how to remove the two lenses on the center dome lights, I want to changeout to LED bulbs on my 10 Genny 4.6
Thanks
