Changing oil without changing filter?
MarsellusWallace
Portland, OR
I just did the first oil change on my 4.6 but my ramps kept slipping on the garage floor, so I couldn't get access to the filter. I'll probably come back to it this weekend. Is there anything wrong with changing the oil but not changing the filter right away?
Oil filters supposedly can handle multiple oil changes. I think most people like to change them every time anyway. I do.
I would not recommend. The filter "filters" and holds dirt and containments.
In fact, I would be more inclined to replace the filter more than the oil- a filter swap takes 2 minutes and can extend oil life.
No filter change will result in at least 1/2 quart of dirty oil remaining in the engine. Not good. Oil is the life blood of an engine and dirty/contaminated oil does damage an engine.
Will it hurt the car? No not really. But the thought is, heck, you're already down there, and a filter is so cheap, so why go half way on a job? Also, on a new car, I would be more inclined to replace the filter than the oil, due to high levels of wear metals during the break in period. Also, the last time I changed the oil and filter on the V8. The oil filter housing had a lot of caked on gunk on the top portion of the plastic housing, that I had to remove with a towel.
Although this is from a V6. (Kudos to Sayantsi). Once you pop the old filter out. It's the internal portion of the housing cap that is full of thick gunk that I had to remove with my finger and a towel:
Better yet, spend a few dollars and take it too the dealer. It's not like it's a bank buster!
