Check Engine Light and Gas Gauge Reads Zero
Brof16
2012 Genesis R-Spec: just filled up with gas. Started car and got check engine light and gas gauge reads zero. Tried restarting several times. Same result. Any help? Thanks.
I would advise to take it to the dealer while the problem is happening.
They will most likely replace the fuel level float sensor.
Gas gauge at zero + CEL is most likely a sender issue as mentioned above. I've had a gas cap fail before and it threw a CEL but the gauge still worked.
Get a $15 OBD2 reader off ebay and download Torque to pull the code if you really need to know...
