DCT transmission
Kellyberg
San Antonio, TX
Every once in a while, when at low speeds and making a turn, the transmission feel like it is not engaged and not pushing the car forward. It only happens of a second or two. I was told by the dealership that it is a trait of the Dual Clutch Transmission that is the Genesis. Could that be true, does the Genesis have a DCT, or is it that since it does not happen often the Dealership dose not want to be bothered or dose not know how to fix it? I could not verify the transmission claim of having a DCT in the car.
Given, I have not had a great experience with the dealership and would not go back to them for my next Genesis...I do love the car.
Is the transmission actually disengaging or is your throttle input dropping? if there was a transmission issue the engine rpm would indicate slippage and you'd probably have a check engine light. Drive in Sport mode and see if the behavior at low speed changes.
The 8 speed is a dual clutch design, but at low speeds it shouldn't be disengaging unless you're making it hunt between 1st and 2nd.
I will give it a try in sport mode. Thank you, now I know it is a DCT and the dealer service rep was not BSing me. Thank you for your prompt response. There is nothing like advice from an actual owner and not a tech who drives a Honda.
Is the 2015 3.8 8speed DCT as well? If it is something is wrong because of spow up and down shift responses.
In watching the video, it doesn't sound like a DCT/DSG transmission. But rather, an improved multi-clutch conventional transmission with the ability to skip gears to improve economy and smoothness. Thoughts?
So it is mct not dct?
Hyundai has re-programmed the 8 speed for the 2016 MY. Further hardware enhancements were made for the Genesis 2017 MY.
Remember, these transmissions "adapt" themselves to your driving patterns. If you change how aggressive you are with the car, it may take time to adapt to you. If memory serves, others have discussed this. I think several other members have pulling the power to "reset" that transmission computer, thereby causing to re-learn your driving patterns.
My 2015 does the same thing. Noticeable only when accelerating from a dead stop, sharp turn and more than light throttle. I'm pretty sure it's because of inner front tire slippage. The computer recognizes it immediately and reduces the throttle.
Dual
Clutch
Never
Again
In a
Billion
Years
