DIS Engineering mode on 2015-16 Genesis?
What are the codes for the full engineering mode?
click and hold "setup" + "menu" and " track ^" you acces to eng menu and on the right you have full eng menu option -> password: 0428
Hello everyone
I would need help
I think I had an error when entering the engineering mode in my Genesis 3.8 ultimate and I do not work any of the cameras
As you have much more information than I that I am new I would appreciate any help that you can lend me
It works absolutely everything, radio, navigator park assist, absolutely everything but no parking aid camera
Thanks in advance, any help will be welcome
Unfortunately here in Spain, the dealers have no idea to solve these things as they have sold only 20 units per country
Best Regards
Javierdos
HI ¡¡
The problem of my previous post was easy to solve, simply entering the full eng mode, there is an option to restore the system to factory, once activated re-recognize the cameras in a few minutes
Greetings to all
Javierdos
On the Ultimate trims, the Set Up button is a Disp (display button). Any clue how to enter the engineer mode for an Ultimate?
Hey guys,
Did anyone figure out how to access the Engineering Mode Menu on the Ultimate trim?
Thanks,
How do you enter the full engineering mode/Menu on the Ultimate trim?
Thx,
Is there an engineering mode on the 8" Touchscreen system? The touchscreen radio's physical buttons are different to the one with the controller wheel.
Also, if there's a difference, I'm in Europe and believe we have different firmware.
Thanks in anticipation
Ben
yes i found it.
bluelink + menu + track ^
this works on a 2015 genesis sedan 3.8 awd ultimate option with the 9.2" screen and DIS control knob by the cup holders.
press all 3 for about 2 seconds and eng mode should pop up
the bluelink is the B below the big knob in the picture.
then enter 0428 for the eng password.
doesn't work on a 2018.
That password doesn't work for me, any other suggestions?
You can try these from my forays into the system:
  • software: 1358
  • hardware: 4763
  • dynamics: 0716
  • update: 4590
  • log: 4259
  • autotest/ETC: 4260
  • variant: 6172
  • diagnosis: 5173
  • mapcaremode: 3649
Full engineering: 0428
If you get into full engineering you need no codes for any of the named functions above.
go to settings->system info->storage and than tap 5 times on the bottom left corner and once on bottom right corner of the storage info window. Not corners of the screen, just the window with storage info, well ,right corner of the window is also corner of the screen
