DIY oil change and filter comparison
wd40
Lost Wages
Oil Filter Comparison
Purolator L25848-57 pleats
Mahle OX 351 D-54 Pleats
There has been a lot of conversation as to what type of filter replacement should be used (OEM vs. aftermarket). Certain forum aficionados are hardcore OEM while I’ve read aftermarkets are of high quality. I change the oil on my unit twice a year, which might be overkill since mileage varies between 550 and 600 miles per month. I decided to order two recommended oil filters and compare the quality. Both were ordered from Amazon with free shipping over $25.00. I also ordered an air filter to get me to the free shipping mark. I suppose I could have ordered five or six different brands but after looking at them I wonder if there would be any significant difference.
I purchased my vehicle with just less than 3K miles (it was driven by the owner of the dealership) and the dealer did a courtesy oil change prior to delivering the vehicle. The shop receipt shows 5W-30 Castrol Synthetic-I asked them to use synthetic. The owner’s manual says you can use either 5W-20 or 5W-30 but using 5W-20 increases fuel mileage. Interesting concept, but in the desert where the temps are 110 plus several months a year I figured to use the 5W-30. Probably makes no difference.
Odometer just hit seven thousand miles so I decided to give it a go, do it myself and save a bunch of money. I’ve attached a few pics of the two filters. Ironically the installed filter the dealer used is a Mahle. Sure wish Hyundai would make some sort of access panels so we don’t have to remove the skid plate (engine cover) whatever. By the way, I know there have been issues on the forum regarding oil consumption but I guess I’m one of the lucky ones. Not a drop below the fill mark since the last oil change.
Both filters seem to have a high degree of quality. Filter media is slightly different.
Mahle OX 351 D-54 pleats of filter material.
Purolator-57 pleats of material.
The pleat material in the Mahle (is slightly longer but the Purolator has hard plastic end caps with plastic spacers and O-rings. The Mahle has a woven fabric type material for end caps with no O-rings. The Mahle appears to be a compression fit.
I called both manufacturers in an attempt to get some technical data on the filters. Simple questions, what type of media is used for construction and how many square inches of media are in the filters? Mahle and Purolator took my number and said they would research it and call me. I’m still waiting.
I also asked Purolator where the filters are manufactured. As you can see in the pics the top of the filter says made in Korea but the box says manufactured in China. I asked if the filter was made in Korea and maybe the packaging was made in China but no one knew the answer. I added some interesting reading I found regarding filters with testing. That’s it-my car is happier since the oil change. Happy motoring.
http://filtrationcomparisons.weebly.com/test-pictures-and-results.html
Oil Filtration Comparisons From the Workbench
Home
Do Oil Filters Even Matter?
more...
Do oil filters matter?
That depends on who you talk to...or what you read.
The late, great Bob Winters of Bobistheoilguy.com fame ran his car with the oil filter completely bypassed to see if it would make a difference on used oil laboratory analysis results. Apparently there was no conclusive evidence that the filter made any difference in the oil contamination levels that the laboratory analysis could detect.
...In my opinion, since there seems to be a limit in particle size that oil analysis labs can detect, this does not necessarily mean there were no filterable abrasive particles in the oil anyway.
Remember the original Volkswagen Beetle?
These engines originally used no filters at all and they seemed to reach 100,000 miles at least as often as other cars' engines that had filters.
...To be fair, the strategy for a well maintained, long lived old VW engine was to change the oil about twice as often as filtered engines required it. This would certainly get rid of most of the build up of abrasive particles and sludge in the VW engine.
Ford Motor Company experimented with some of the first full flow oil filters (the modern method where all oil must pass through the filter on the way to the engine internals) back in the 1950s and found an approximate halving of abrasive engine wear...And this with the likely primitive filter media available at the time.
Other credible sources say that the filter you choose is more important to engine longevity than the oil you use.
...But then again, look how cars so often go 200,000 or even 300,000 miles nowadays with little owner thought or knowlege about filters or oil. They just use whatever the shop or oil change place uses.
Bottom line for me? Having seen the junk stuck to used filter elements that have been opened, I don't want that stuff flowing around in my engine between oil changes.
Next: Flow vs Filtration
Create a free website with http://www.weebly.com/?footer
Putting 35k to 40k a year on a car I do 7 oil filter changes a year. So I now have done 21 changes on my Genesis. I always use the OEM filter by Mahle boxed by Beck/Arnley from Advance Auto Parts online.
The Purolator you have is the exact same as Hyundai OEM filter for 2009-2011 V8, and also 2009-? Genesis V6 (not quite sure about V6 from 2012+).
The Mahle is the Hyundai OEM filter for the 2012+ V8.
So if you have a 2012+ V8 you should not be using that particular Purolator, since Hyundai decided to change the design, although I cannot guarantee that the Purolator will cause problems. If you have a Genesis 2009-2011, the Purolator would be exactly the same as the OEM, right down the little plastic molding dimples on the black end-caps and the green O-rings inside at both ends (not to be confused with the O-rings that go on the oil filter cap/wand). BTW, the 2009-2011 OEM and Purolator you have is made by Mann-Hummel.
Sorry Mark but you are incorrect re:when/what OEM filters were used. MY Genesis 4.6 built in June of 2010 and I purchased new in September 2010 with 26 miles on it came with the Mahle filter and I did the first oil change myself at 5000 miles.
OK, thanks for that clarification. Now that you mention it, I remember you said this before and I forgot. What is your build date?
I believe that Hyundai now specifies the Mahle for the V8 retroactivity back to 2009, even though I am pretty sure (based on V8 owners who have posted on this forum) that only the black Mann-Hummel filter was available in 2009 (and maybe early 2010). I noticed this on several online parts sites run by Hyundai dealers. Apparently Purolator still thinks the Mann-Hummel is OK on the 2012.
In 2009, there was a lot of confusion about the difference between the V6 and V8 oil filters (the black Mann-Hummel version) because the Hyundai part numbers were different. It turns out the filters were identical, but the drain plug washer package was different. Then later they came out with one part number that included drain plug washer parts for both engines.
My main point is that the Purolator (and also others like Fram, etc for the Genesis) are identical to the Hyundai OEM filter that is made by Mann-Hummel.
Here is the Fram.
[ame="http://www.amazon.com/FRAM-CH9999-Full-Flow-Cartridge-Filter/dp/B000PAOAF6/ref=pd_sim_sbs_auto_7"]Amazon.com: FRAM CH9999 Full-Flow Lube Cartridge Filter: Automotive[/ame]
And Wix:
[ame="http://www.amazon.com/Wix-57250-Oil-Filter/dp/B002PMOP2A/ref=pd_sim_sbs_auto_1"]Wix 57250 Oil Filter : Amazon.com : Automotive[/ame]
Hastings:
[ame="http://www.amazon.com/Hastings-Filters-LF642-Filter-Element/dp/B004AME2KI/ref=pd_sim_sbs_auto_8"]Amazon.com: Hastings Filters LF642 Oil Filter Element: Automotive[/ame]
Mark said "OK, thanks for that clarification. Now that you mention it, I remember you said this before and I forgot. What is your build date?"
My build date is June 16, 2010, its a 2011 4.6 with tech package standard.
The problem with this study is that it is very unlikely that it applies to the Hyundai Genesis filters distributed by the companies mentioned. As I mentioned above, almost all of these Genesis Sedan filters with black end caps are/were made by Mann-Hummel, and these companies just distribute them. The study probably does apply to screw on filters for high volume applications/sizes that they make themselves, although these days more and more products are made by contract manufacturers in China (and a few other places near there) and the companies we all know are getting into the product design and distribution business and out of manufacturing. This is no different than most other products/brands.
I'll use almost any filter other than Fram. Got a Wix going in on my next oil change. (and no I don't need any education about Fram filters for our Gennies.)
I get mine a http://www.newhyundaiparts.com
The black Hyundai OEM made by Mann-Hummel for my 2009 V6 costs $5.48 each. I do pay shipping, but no sales tax, and I order enough oil, air, and cabin filters at one time make shipping cost not a significant cost per item.
Not that I really believe that any one filter would be inferior to the other, I just stick with the OEM while under warranty to avoid any hassle from the dealer/Hyundai. Only $10 at my dealer so no big deal to me.
I agree. Just to be clear, http://www.newhyundaiparts.com is run by Hilton Head Hyundai in SC. You can call their parts department instead of ordering on the internet. There are a few other websites also run by authorized Hyundai dealers that might be of interest to those on the west coast to minimize shipping costs.
It costs me $8 in gas round trip just to drive to my dealer.
I noticed the Wix and the Hastings small o rings are a different size. I have a 2012 4.6 and the last filter I bought had the smaller o ring (Wix) that did not seem to fit, should I have used the larger small o ring like the Hastings? Curt
The Wix photo looks correct. There are two O-Rings which fit on the plastic oil filter cap. The small one is a little hard to get on/off (actually is quite hard to get on/off, which I had to do for an oil change I did last night). You should have noticed the existing small O-ring near the end of the wand for Oil filter cap. I used a small jeweler screw-driver to help get if off and new one back on. I would bet money that some dealers don't change the O-Rings for every oil change they do.
I suspect that the pic for the Hastings is not to scale and that someone photoshoped two separate pics of the filter and O-Rings into one pic, so the O-rings look larger than they are.
Okay, I did not notice that the small o-ring was for the top of the oil filter cap. I thought it was for the drain plug on the filter housing for draining the oil from the filter housing before taking off the cap . Curt
You had me confused for a minute. I have a 2009 3.8 V6, and even though it uses the same filter housing and filter, it is on top of the motor in the engine bay, and everything is upside down compared to your perspective on the V8.
$17.74 for a stinkin' oil filter......... no thanks! I'll stick w/O'Reilly's auto parts or Amazon. ~$10.
I just bought a few oil filters at the dealership where I bought the Genny here in Canada, $16.34@. What a rip!!! ..... :(
Thought I'd go OEM for warranty reasons. Don't know if it really makes a difference, OEM or not.
RonJ
Amazon mahle OX351 D 7.95 each.
I don't know where you came up with $17.74. I buy Hyundai OEM filters (the ones with black end caps for the V6) online for about $5.85 each plus shipping, but no sales tax. I buy them 6 at a time, plus air and cabin filters at same time, so shipping cost is not at issue.
