kdjlaw
- May 22, 2012
- Location
- Baton Rouge, LA
- Genesis G90
I searched and can't find that this issue has been discussed.
I have a 2015 5.0 Ultimate.
The driver side front door requires more effort to close than the other doors, and a little more effort than I think it should require. If I close it with the same effort as the other doors (or with the same effort it took to close the door on my 2012 5.0 R Spec) it "catches" but doesn't close completely.
I took it in to the dealership (I had a couple of other small issues) and they said it was "because the car has such a tight seal." When I picked the car up I showed the service advisor that the driver side front door takes significantly more effort to close than the passenger side front door. So much for the "tight seal" explanation. He sort of shrugged his shoulders and said, "It's a 2015 and they haven't worked out all the bugs yet." He also indicated that even if they acknowledge it's a problem, they don't know how to fix it.
Anyone know anything about this?
