Yes my seat has a similar problem , no movement when pushed in any direction but feel a shift under seat in corners .This problem seems to be getting more frequent. It’s a 2016 Genesis with the ultimate package. It’s really distracting going in a curve. I posted this problem in the G80 forum and a member gave me a link to a TSB on AboutAutomobile. I called my dealership about it and they said all car seats have some play in them. BS! He said there is no TSB. The number I gave him was invalid. He said bring it in and they would look at it. Is anyone having this kind of problem?
My 2016 Ultimate has recently started with this seat issue. Sometime ago I stumbled on this info that I will be showing my dealer and might be helpful to members here. Search TSB 20-BD-009H...this service bulletin seems to be spot on to this issue. I will be using it in the coming weeks when I schedule my fall oil change.Hope this helpsYes my seat has a similar problem , no movement when pushed in any direction but feel a shift under seat in corners .
This started after side air bag replacement which required the seat to be removed .
Am I correctly understanding that you had this "repair" done under TSB 20-BD-009H and now about a year later you have the same thing happening?? if so that is very interesting. Seems others have had the entire seat "rail" system replaced with mixed results alsoIt's been almost a year and I'm starting to feel it again in tight turns. Apparently the parts they are using are the same, not engineered to correct the problem.
They replaced the seat rails on my 2015. TSB 20-BD-009H is a clip on the 2016 models. It was great at first then maybe a month ago felt it slide a little side to side, Not near as bad as before but I'm sure in time it will be. What bothers me is they did not fix or re-engineer the part, just replaced it with a new defective part.
h
I believe the repair part # is 88535-B1000FFF to the issue above...seems this part is a type of o ring or cir clip that when used prevents seat movement
Thanks..appreciate the info...will keep in mind and have mine looked at in the spring (when I take her out of hibernation...from the salty winter roads here in MI)I had this repair done this week on my 2017 G80 and it seems to have fixed the problem.
For now. It came back in less than a year om my car. It's a design issue they are not changing.I had this repair done this week on my 2017 G80 and it seems to have fixed the problem.
