You're encountering the exact same problem with two different cars...that is, unresolvable audio issues? The odds of that are incredibly low.
You seem convinced that a new BMW will be the solution. I hope it works out that way for you, but the collective experience of numerous ex-BMW owners on this site don't bode well.
Perhaps you should send a written letter to HMA. E-mails are easy to ignore. But if you do, go easy on the caps, man...no one likes to be yelled at.
I have to tell you, I had a 2009 that did the same thing within 4 days of purchase back in October 2008. The dealership was witness to it, changed the head unit and eventually I was swapped out of that car with another 2009 Genesis in November 2008 when the problem kept recurring and the car was in the shop all the time.
Within a week, that new car did the exact same thing. It was not funny. What solved it for me was changing the amp, but it seems that this poster has had no luck with that.
I had it happen just once on my 2011 Genesis and never again. I did have one peculiar problem with the 2011 is that many times when I started the car the radio came on even though it was supposed to be off. You couldn't adjust the sound or anything like that until you pressed the button several times and finally shut it off and then on again. I had a loaner 2011 when my Equus was in for service and it did the same thing.
I've had it happen once on my Equus and has never happened again (knock on wood).
For those of you poking fun at the OP, we all have the same system, even the 2012s and this can happen to any one of us at any time. It is quite frustrating and it can render the blue tooth, voice command, CD, DIS knob, or nav system useless...the malfunctions can change with each incident.
To the OP: if you write emails like you post here, they may not take you seriously. You need to demand that a case be opened up on your car by Hyundai and it wouldn't hurt to have the advice of an attorney. Have your service record and document meticulously. Show them steely calmness and let them know you have all the paperwork ready to go.
Good luck to you
to all those that are just talking about my caps and don't have the same trouble with your cars !!! I'm happy for you that you have not gone through what I have. But my CAPS was to let you guys know how upset I am with a car I truly like and can't get to work right !..... I guess I'm the only one that can't get the car fixed and everybody else has the ipod , nav, audio, work just fine for them. But it is not what expect in a high end car today.
2011 4.6... 7k+ miles. Not one electronic issue. I like the Nav, Bluetooth Phone, Bkup Cam, CD, IPod, and XM. Never user the AM/FM. How many miles are on your cars before these issues start? Mabe I'm still in the honey period of the car. Maybe it is the AM/FM radio that causes this. Has anyone found a common denominator? Like...whenever you switch from FM to CD the system shuts down?
Just my 2 cents. . . I think the issue lies in compatibility between Hyundai car electronics and Lexicon components. This hypothesis was first put forth a long time ago by another poster and I agree with it.
Not sure what that could be....interference issues? Or, as I noted, HEAT buildup issues. One thing that that all devices have in common is susceptibility to heat build up.
Its not like a memory problem where you reboot the system and a reset clears things...shut things down and the device starts working again in 15, 30 or 45 minutes... I'd bet a buck that is, in fact, heat related. The components are not able to adequately dissipate heat...the solution might be as simple to solve as installing some sort of cooling fan or duct under the dash to keep things cool....
Shove your home PC, or i-pad, and/or 'droid or i-phone, or whatever in a small box with your GPS and stereo all running. Now, block off the cooling vents...and now put that entire setup in a 100+ degree box of it's own (how hot does the interior of the car get before you get in and turn on the A/C, remember the dash board is black and collects a LOT of solar heat)....how long does it last before any and all of the things stuffed into that box start exhibiting odd behavior? Shut it down and let things cool off for a bit and things will start working fine again (unless you've blocked the cooling ports/vents again). But in some cases, components can fail internally (chips) so that certain functions won't work, or will not work as expected. The system could be permanently degraded due to overheating. If you are driving 17 speakers at volume, that amp probably gets fairly warm under that dash. Maybe they have a wimpy built-in fan, I don't know. But if it walks like a duck, quacks like a duck, and looks like a duck, chances are, it's a duck.![]()
I doubt very seriously if this is heat related as if it were it would happen more frequently. I have also seen it happen after the car has sit for a long period of time giving everything plenty of time to cool off.
In sixteen months of ownership the Audio/Nav have failed four times which means on an average my Audio/Nav have gone down every four months. It is always the same when I park the car and come back later and start it up Audio/Nav is working.
It could very well be some sort of electrical interference or a short, I do not know but you would think the people at Hyundai would figure it out.
To date this issue and the tilt wheel issue still go unresolved and have carried over to the 2012's. I have contacted Hyundai and voiced my concerns. The only thing I and everyone else can do is to wait and see how Hyundai handles this.
IF a new car off the assembly line or in a dealer's showroom malfunctions, I'd buy that bad components are the root cause. However, heat-stressing components will eventually cause failure in components that are borderline to begin with. Believe me, I know. I have a main hubroom in this facility which has 'iffy' air conditioning (yea, the DoD won't put a lot of money into it). So many times over the past year, we get alarms where the temp has shot up in the room to 90, 100, even 110 deg F. We get the techs there to fix things and temps come down, but no after damage is done. We've lost power supplies, boards in Cisco switches, etc but still, they do nothing to replace the A/C. But the damage is not always apparent.
As for a 'short', that's not really a correct term to throw around...shorts cause fuses to blow. Shorts melt wiring, etc...but the only OTHER thing I can stretch a possible failure argument to would be...power. The main source is 12V, of course, but electronic and computer components typically use anywhere from + 3.3V DC, +/- 5V DC, +/-12V DC. The power feeding the different components has to be filtered, and poor filtering can cause component failure due to voitage spikes, etc. Poor filtering can allow spurious signals (or emf) to cause odd behavior (for example, the trucker with that 1000w linear CB amplifier in the lane next to you). But something like that is usually transient.
Very detailed documentation would be needed to track this..such things as:
Does the malfunction occur when the engine is running?
If so, how long after the engine is running?
Does it occur when a specific mode is enabled (XM, FM, etc)
Does it occur on cool days?
Does it occur when the cabin temperature is above 80 deg F?
Does it occur after the +12V cable has been disconnected for several minutes or hours (ie system reset?).
Does it occur when the A/C is operating?
Does it occur after any specific thing happens such as rapid acceleration? Or after the power windows are used? Or the remote locking mechanism is engaged or disengaged?
Does it occur when the seat heaters or cooling is engaged?
Do you have a radar detector installed?
and so on an so forth...DETAILED logs or records of when and how the malfunctions occur are necessary... that way, Hyundai can then look at what is common to all failures in the vehicles. For this to occur in as many vehicles as it does, there IS a common thread. It might be as simple as ONE component.
Replacing head units and other things are just stop-gap measures. Shotgun the problem first then narrow it down. If a head unit is replaced and the problem recurs, then you have to look at what the problem is NOT instead of what it is or could be. The process of block diagramming and flowcharting wold be invaluable with this wonky problem.
So I still submit that it is heat related or heat induced, and add that it may be power related as well. Two good starting points for Hyundai.
I guess we will know the real answer when Hyundai resolves the problem.
