Front parking sensor issue
I too had one of the middle-front parking sensors go bad. After driving a couple months with the blinking warning light on for about 50% of the time, i replaced them. I did have the take the bumper off the car to access, but it wasn't too bad. Didn't remove the headlights like some suggested. Replaced both middle sensors for $45/each, and it took about 2 hours.
Very common. Easily repaired. Defective front parking sensor. 15 minute job.
Hi Waki: I see lots of similar problems to my own 2012 Genesis R Spec. Front right parking sensor....3 beeps whether or not anything is in front of the car. Always happens as the car slows to a stop. Indicator green triangle shows right front. Your post says easy 15 minute job. I am very handy but cannot find any post on how to replace the sensor without removal of front bumper.
Can you help with a post or a video please?
Here is an easy thing to try before spending any money. Found this by accident. Same problem, parking sensor would come on and beep anytime I went below 10 kmh. Didn't matter if part assist was on or off. On top of this my back up camera screen was black. Went away for 3 weeks and when I came back the battery was low (6vdc). Got a boost and away I went. No more beeping when I slowed down and the camera was working again. I think I will pull the proper fuse next time, just need to find the proper fuse.
I am also having the same issue. I thought it was the front right middle sensor as it did not beep during troubleshooting. I bought a brand new OEM sensor, replaced it, still doing the same thing. I guess i have more troubleshooting to do
Hey everyone.
Not to revive this thread from the dead, but does anyone know if there is a way to disable a parking sensor in the rear.
I constantly get that annoying noise and blinking image for a rear sensor when I start my car and I don't have the money to buy a new sensor.
Pushing the parking sensor button, even off, has no effect.
Anyone know if there is a way to disconnect one, or all, of the rear sensors to keep this from happening, even at the expense of having them support me on my backup endeavors?
I suspect "disconnecting" them is exactly what's causing the beeping. It's the computers way of telling you I don't see a functioning sensor. And I think it may be caused by issues with the connectors. I'd like to get at mine, pull the connectors apart, spray a little lithium grease in them, and plug them back up. I'll bet that would fix it.
