BBQ Bandit
just bought one yesterday, excellent video.
might i add one thing. by using denatured alcohol as opposed to the multi-surface cleaner and goo-gone you can eliminate the two step process at the end after removing the physical emblem. the denatured alcohol works awesome. it will not damge the paint it will remove all adhesives, even smaller chunk pieces you would think you need to pick off, waxes and evaporates instantly.
i also would suggest you ONLY use fishing line or some type of plastic coated string (or floss) like the op as anything else will leave fine scratches requiring additional compounding for no reason. things i have found out the hard way over 22 years of removing emblems from my cars/trucks.
and remember without a hairdryer or heat gun you will be picking adhesive chunks off for an hour unless the car is in the sun.
Thanx for the tip - denatured alcohol... took care of the adhesive in quick order.
The Genesis is sporting wings!
