GrimmSpeed Manual Boost Controller - Product Release!
GrimmSpeed
Our first Genesis product!! :)
http://www.grimmspeed.com/catalog/product_info.php?cPath=91&products_id=165
Price: 89.99
GrimmSpeed introduces the most refined Manual Boost Controller available on the market. Our Manual Boost Controller allows you to raise the OEM boost levels in a quick and efficient manner. Adding the MBC will result in Quicker Spool Up, Quicker Response, Increased Horsepower, and Increased Torque.
Innovation is the standard here at GrimmSpeed and we have continued to push the envelope with this product as well. We have created a MBC that only requires one spring for both high and low boost settings! No more changing out springs! Our spring offers very fine adjustability...we have achieved this by creating an extra long spring with a large adjustment range and a very fine threaded adjuster. The spring will outlast the car as it is made from Stainless Steel. Unlike the competition who uses heavy steel balls, we have used anUltraLight Ceramic Ball that will react much quicker.
The Bleeder Port is designed to precisely and quickly bleed off wastegate pressure so the wastegate closes quickly while not being large enough to affect mass air flow readings. It is also designed to further dampen boost spikes.
Boost pressures over 35PSI are obtainable if needed yet it still offers fine enough adjustment to only raise the boost in very small increments.
Justin
Nice looking product. I sure wish you would come up with a mod for the Genesis Rotten Shocks to be adjusted they are gas and twin orifice.
Taping into the right spots with a quicking acting adjustable snap valve like you could make out of the above unit, to bypass some of the pressure from the high side to the low side would solve most of the problem. These shocks are wy too stff.
Good luck on the business, Don lewis
