Perhaps our documentation expert (aka Ric) can plumb the depths of HMA documentation and uncover the facts.
Nothing in there about calibration or self-test modes, only stuff the dealers can test/calibrate with their laptop connected. However, trolling through this swamp produced a revelation not mention here before. In the repair procedure you have to tell the laptop whether the car has
AIR SUSPENSION , or not. I assume this is the Korean version of the car which also has the cooled front passenger seat, etc. But AIR SUSPENSION tells me there must be a console switch where you can select ride characteristics. How many of you have been waiting for that gem.
If the car has air suspension, there are 4 sensors for the height adjustment on the lights. Our version of the car only has two.
2009 > G 3.8 V6 DOHC (G6DA) > Body Electrical System
Description Adaptive Front-lighting System (AFLS)
AFLS(Adaptive Front-lighting System)is a headlamp orientation control system that takes into account both steering angle and vehicle speed to orient the headlamps to an angle that provides better nighttime visibility.
Variable conditions make beam pattern of running vehicle kaleidoscope.
Component of AFLS
1.Input part : It is provided that information of speed sensor, height sensor and so on related to condition of vehicle.
2.Control part (AFLS Unit) : It controls Output part by analyzing/judging Input signal.
3.Output part : It drive Low beam of H/Lamp to upper/lower and left/right side optimum beam pattern according to output control signal of AFLS Unit.
Main function of AFLS
Content Description
1 Dynamic Bending (Swivelling)
• Providing optimum beam pattern in the curve road
1.Enhanced visibility in the curve road
2.Drive Low beam to left / right side
2 Automatic Leveling (Leveling)
• Compensating Low beam according to inclination of vehicle
1.Compensation according to static condition (Load)
2.Compensation according to dynamic condtion (Quick start, Sudden stop )
3 Fail-safe
• Fail-safe reaction while detecting system failure and malfunction
1.Detecting signal / communication error for Swivelling
2.Detecting signal /communication error for Leveling
3.Detecting system failure
Advantage of AFLS
Content Description
1 Enhanced stability
• Visibility Guarantee In case of curve road
• According to vehicle Speed/Steering angle, speed/angle of Swivel actuator is automatically controlled to provide optimum beam pattern
• Fail-safe reaction application for Driver on opposite side road
→In case error communication,automatically return initial position of Swivel actuator
2 Enhanced convenience
• AFLS operating application by driver's selection(AFLS Off switch)
• Providing Diagnostic function for detecting system failure and malfunction and check up data information (by using Diagnostic equipment )
• Reduced wiring-harness by Applying CAN/LIN communication in vehicle
• Fun Driving Function : Swivelling of Low beam
→ Increasing driver's pride
[I love this part
] [ROFL, ROFL thinking of you guys watching the beams jump around on the garage wall]
Operation Component
AFLS Unit (A)
1.General
System initialization, In case of input Engine signal (AFLS ECU, Levelling /Swivelling motor)
Adaptation of AFLS OFF switch
AFLS operate normally ,only under turning low beam switch on.
Providing Tell-tale function of AFLS(display 'AFLS OFF' on dashboard)
In case of system failure, display blinking 'AFLS OFF' on dashboard.
2.Main function
Swivelling function
Levelling function
Processing signal of Height sensor(Air suspension)
Swivelling Actuator (A)
1.General
communicate AFLS Unit through LIN protocol
Robust control to Disturbance
Doesn't work out of rated voltage range.
2.Main function & Rating
Fail-safe function : In case of detecting malfunction or system failure , drive to secure position
gear ratio (150 : 1)
Operating voltage : 10V ~ 16V
Operating current : 100mA
Levelling Actuator (A)
1.Main spec
Drive Low beam to upper / lower
Drive type : Micro step mode (1/16)
Height Sensor
1.General
Height Sensor connecting body & suspension measures inclination information from load condition.
Vehicle having the Air-suspension system transmits inclination signal to AFLS ECU by using CAN protocol.
Vehicle having the Steel-suspension system transmits inclination signal to AFLS ECU by using Hard-wire.
2.Rating
Rated Voltage : 5V ± 5%
WASN'T THAT JUST MORE THAN YOU NEEDED TO KNOW?
