Help Needed to fix Rapid Battery Discharge caused by door locks.
CaliRVAdventure
I have a 2009 3.8 sedan. Recently there has been a large (2.0 amp) drain on the battery with everything turned off. I checked all the circuits and found the drain on the 10 amp fuse labeled Body Unit 2 (in the fuse box below the dash on the drivers side). When I pull that fuse the drain disappears but the doors don't lock/unlock electrically. I don;t know where to go from here and need help.
One possible clue: Recently the lights stopped blinking when locking the doors with the key fob. They blink normally when unlocking the doors with the key fob.
Any suggestions will be greatly appreciated.
Classic symptom of missing rubber stopper on the under-hood alarm switch. The blinker flash confirmation is not occurring because the IPM (aka BCM) detects the problem, and it is telling you that the alarm is "not ready" to arm, because it thinks the hood is not closed.
See here: battery draining when car in garage, is a parasidic draw my problem?
Thank you Gunkk. It worked! I simply opened the hood and disconnected the connector on the hood open button and Voila! Issue resolved.
