Help with finding front side marker lights.
larryb1151
I have a front driver side marker light not working and can not find access to the light, can any one help?? Thanks
What year is your genesis? We need to know if your headlight is the newer type or the old type.
2009 4.6 4 door
You should have access to replace the bulb yourself. Here is a picture of the bulb location. You simply twist the bulb bracket(C), remove the old bulb, and install the new one. As far as how easy to get access to remove and install them, I am not sure because I never have done it myself before.
That is definitely not how it works on mine. my 2009's marker light is inaccessible. It looks like you need to pull the whole bumper cover just to get the lens out to change the bulb. I guess I will be taking it to the dealer.
When I had my marker lights in my 2011 4.6 changed over the winter (for state inspection, I had blown one), the service shop said that the bumper had to come off. Most expensive bulb ever!.. :-)
The service manual for the 2009 doesn't mention anything about removing the bumper though. But you do have to remove the lighting housing, which might be the gotcha here. I've attached the appropriate page from the service manual. Perhaps it will help.
Yeah I thought it would just be the housing to but the headlight extends behind the fender and the bumper cover/grill. I see no way to get it off without removing the bumper cover. I watch a youtube video for a 2009 sedan but my light done look like the ones coming off that one.
While it may seem daunting at first, pulling off the bumper cover should be relatively simple. I've done it several times on my Genesis Coupe and got to a point where I can get it off in 5 minutes. I also had to remove the light housing to change bulbs but that didn't require bumper cover removal.
It is so frustrating. I can touch the cap to the bulb with 1 finger, but I can't turn it.
