Hyundai Genesis Coupe R-Spec Information
Sal Collaziano
Genesis Motors Forum
Staff member
Florida
Hyundai Debuts a HIGH–PERFORMANCE BLANK canvas for tuners: GENESIS COUPE R-SPEC
CHICAGO, Feb. 11, 2009 – When the colors of your new turbocharged rear-wheel-drive sport coupe are named after international racing circuits, you’d better have the performance and confidence to back it up. Now, Hyundai is upping the ante by announcing an R-Spec version of the all-new 2010 Genesis Coupe, designed to appeal to true enthusiasts who want a low starting price and the ability to tune their car to their own specifications. R-Spec will be available as a mid-2010 model year introduction.
R-Spec provides genuine track-readiness in an affordable model. The R-Spec adds core performance equipment to the most affordable 2.0T model, such as: Track-tuned suspension, 19-inch gunmetal-finish alloy wheels with performance summer tires, Brembo® braking system, Torsen limited-slip differential, and R-Spec badging. To further reduce cost and weight, it also eliminates some non-essential convenience equipment such as: Bluetooth®, automatic headlights, cruise control, trip computer, chrome interior accents and steering wheel audio controls. The Genesis Coupe R-Spec will be priced at $23,750 and $3,000 less than the 2.0T Track model, leaving tuners with extra cash for their own choice of aftermarket performance upgrades. Appropriately, the R-Spec will be available in three performance oriented exteriors colors: Karussell White, Bathurst Black and Tsukuba Red.
R-Spec equipment includes:
* 2.0-liter low-pressure turbocharged intercooled four-cylinder engine with dual continuously variable valve timing delivering 210-hp, an estimated 30 mpg EPA highway rating and a top speed of 137 mph
* 6-speed close-ratio manual transmission
* Electronic Stability Control with Traction control, ABS, Electronic Brake-Force Distribution and Brake Assist
* 19-inch gunmetal-finish alloy wheels with staggered-width high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
* Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
* Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace)
* Torsen-type limited-slip differential
* R-Spec badging
* Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
* Tire Pressure Monitoring System
* Front, side, side air curtain air bags
* Active front head restraints
* Driver’s lumbar support
* Air conditioning
* Remote keyless entry system
* Leather-wrapped steering wheel and shift knob
* Power windows (one-touch up and down), door locks and mirrors
* AM/FM/XM/MP3/CD audio system with six speakers
* iPod/USB/Aux jack connectivity
* Projector beam headlamps
* Lightweight temporary spare with aluminum wheel (T135/80D18)
* Note: Automatic transmission not available with R-Spec
Other notes:
The R-Spec Genesis Coupe should be hitting dealerships before summer. Weight should be very similar to a base 2.0T model (approximately 3300 pounds). Hyundai is "considering" a 3.8 (v6) R-Spec model.
So my question is, are they just trimming the non-tuner accessories out of the Track model to make the R-Spec or did they actually add things?
it's like an EVO RS.
same exact everything as far as turbo, power and drivetrain. they just took out all the "junk".
not impressed.
carlos nice
I hope there is an option to keep the HID's.
Since it is already has projectors installing some aftermarket HID's will not only be super simple but very nice looking :D
I have installed numerous HID kits on various cars, would rather do that that pay the extra to get a package with stuff I don't want.
Also again with getting a package with stuff I wouldn't want, getting the upgraded sways, and the Torson LSD in this R-Spec trim is super to me.
Anyone know the bulb type yet?
Oh and I would be up for a the 3.8 6 cyc R-Spec :cool:
Yes because halogen projectors and HID kits work together right? Is that what they taught you on Honda-tech? Funny my car has projectors and they make compatible HID bulbs but that doesn't mean they're meant to be used or safe to use even. HID bulbs, HID projectors, if not for you, do it for the people that have to drive towards you at night
