Hyundai Genesis Coupe Specifications
Sal Collaziano
Genesis Motors Forum
Staff member
Florida
Hyundai Genesis Coupe Specifications:
-- Configuration: Front engine, rear-wheel drive
-- Wheelbase: 2820 mm / 111.0 inches
-- Overall length: 4630 mm / 182.3 inches
-- Overall width: 1865 mm / 73.4 inches
-- Overall height: 1380 mm / 54.3 inches
-- Wheels: 18-inch or 19-inch five-spoke
-- Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo
-- Est. horsepower V6: 306 @ 6,000 rpm (regular fuel)
-- Est. horsepower V6: 310 @ 6,000 rpm (premium fuel)
-- Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel)
-- Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel)
-- Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel)
-- Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel)
-- Block & head materials: aluminum for both engines
-- Valvetrain: DOHC for both engines
-- Valve timing: continuously variable valve timing for both engines
(Dual for 2.0t)
-- Estimated 0-60 mph V6: under 6 seconds
-- Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or
6-speed manual, 6-speed automatic (V6)
-- Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package)
-- Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package)
-- Front calipers: single piston floating (standard), monobloc
four-piston (Brembo package)
-- Rear calipers: single piston floating (standard) monobloc four-piston
(Brembo package)
-- Limited slip differential (Optional)
-- Est. top speed: 149 mph (V6), 137 mph (2.0t)
-- Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder)
Wow, it's a lot heavier than I was hoping. I guess the day of the light, agile, powerful sports car is truly over...unless, of course, you want to spend the money with Lotus. :(
Indeed, those days ARE over.. There are too many federal safety regulations to meet. That, and so many options - all the weight new cars down.. There's going to be an excellent aftermarket for the Hyundai Genesis Coupe. So it'll have more than enough power when all is said and done...
At some point or another, the Genesis Coupe is going to get direct injection - making it even better for fuel economy and quite a bit faster...
just saw this thread, I'm taking notice to the porkiness. Ugh. Wish it was lighter. Hopefully they come out with the lightweight racing version that has been mentioned.
It's mainly all the safety stuff that's weighing cars down nowadays.. And, all the small cars appear to be getting a little bigger..
