Installing LED DRL.. Quick question
Pearlturbo
Genesis GV70
Hey guys, I ordered LED DRL, I pop the hood and we all know its plastic everywhere lol. I got the 5.0 R-Spec, I know to get to the headlights I need to remove the plastic cover that's covering the headlights.. I see a bunch of clips holding it in place...
Now is there a special technique to pop out those clips without breaking anything?
Thanks
You push the center portion in/down and then lift the plastic pins out. Replacing them is the opposite. You push the center out from the bottom, (It sticks out the top now) insert into the hole and press the center back flush to lock into place.
Are you replacing the Hi-beam bulbs with LED's??
Yes I am. Hate the halogen bulb color always on. I'll sacrafice not having high beams. Car comes with HIDs anyway.
You'll lose your Hi-beams with an LED set up like that.
There are Halogen Hi-beams that put out a white light.
Check out Sylvania SilverStar zXe
I'm ok with losing the high beam. I just got the lights in today, plus my Genesis badge. I'll post pics when it's installed. Thanks everyone.
