Interior Dome Lighting
darammer
SFV - LA, CA
My rear dome light (room lighting) flickers for a while on occasion. Almost like a fluorescent bulb does as its warms up or is about to fail.
Anybody elses do the same thing? The light looks white like a fluorescent, but I am not sure if it is.
That happened to me once. Except I noticed the front dome lights flicker after the passenger opened the door to exit the vehicle.
I tried to get it to happen again but I couldn’t reproduce it.
I think the lights are LED. They shouldn’t flicker like fluorescent.
Last night both the front and rear dome lights started flickering for the first time. The rear light was turning on and off really fast, while it was less pronounced in the front light.
Have had my Genesis since August and in over 15 thousand miles, first time this happens.
I have the same problem.. Is there a fix because my dealer gave me BS about being normal.
Chris
Yup, same issue with me - dome light over the back seats flickers every now and then.
Add me to the list. If anyone has a fix please share.
Fiat
Flickering is a characteristic of LED lights when they aren't necessarily seated properly. The issue is they readily show on/off because they instantly light up, vs an incandescent that needs to heat up and holds heat/light through flickers. If the problem exists with an incandescent, you don't generally notice since such minor on/offs don't really show up.
Try tapping on the light, or removing the cover and adjusting the bulb so it is better seated in the light and see if that fixes the problem (twist it back and forth a bit). If the LED lights up, its working, it just doesn't have a constant connection in the circuit, and that usually happens where the bulb meets the car.
