My genesis after Tire Changing to Continental in Saudi Arabia
Uchiha madara
Dear all
in saudi arabia we have a problem with our tires that its blow up without any reason and causing a lot or damages and problems
then the dealership made a recall to change the tires which is (Dunlop Maxx sport Gt) to the same bad tires again if any thing happens or you have an option to change it to 18 wheel size because as standard we always get 19 inch wheels even with V6
i didn't accept to take Dunlop again so i have installed (Continental Contisport Contact 5P) which its available in Saudi Arabia
as per Tirerack.com its a perfect tire
as my testing it this is the 3rd day its wonderful
No road noise
so smooth
it have a great grip and the traction light didn't ever appears to me ever
it so sticky on turns and it giving me a good performance
i knew that you will have Continental on your cars the 19 inch wheels
but it will be (continental pro contact) type as its a recall for you
but try high summer performance tires and you will like what your car can give you
I had seen early reports about the Genesis tires exploding in Saudi Arabia. I'm guessing that the tire they're using can't handle the heat? In any case it's good that you found a viable replacement.
