NAV System tracking
chuck.perelman
I just acquired a 2012 Genesis 4.6, built a few months ago in 2011. The NAV system appears to be off 1/10 of a mile. When you're trying to go to a specific address it's a real nuisance.
Either it tells you you've arrived at your destination when you still have 1/10 of a mile to go, or when you get to a specific address that you programmed in (HOME for 1!) the system says you've got to go another 1/10 of a mile.
One dealer told me system needed to be recalibrated on their computer.
Another dealer tells me that it's normal for the system to be off this much, that the system can't be recalibrated, only updated and that there are no new updates for my system.
Anyone else out there had this problem and know whether it's normal to be off like this?
Hyundai America gave me a boiler plate answer: Your dealer knows how to fix any problems.....
Help will be greatly appreciated on this issue.
Is it off by a 10th of a mile from the road or just not correct regarding the address? If its just the address then its the info in the map software. The nav in our Acura was off by a number or two sometimes and so is our Mercedes. Have not noticed the Genesis being inaccurate yet but I am sure it will happen. Google earth is also not correct when some addresses are entered. As always if garbage goes in from the programers then we get garbage out.
Sorry but just had to respond (since have been in IT since 1980). You are correct about garbage in garbage out. However, this is not a programmer problem. This is a data problem. :)
I've run into a issue when driving one a mountain that was wrapped with many parallel roads at different elevations. The GPS was off or wandering enough that the nav system was uncertain which road it was on.
Does the nav system in the Genesis use WAAS?
My 2012 is dead-on accurate so far. I use the Navigation 3-5 times a week and it takes me to the front door.
I should have said data entry not programers
When I approach my home, with my home address properly entered in the Navi system, system tells me I have another tenth of a mile to go. When I am parked in my driveway, the system tells me that I am at a location a tenth of a mile west of my home.
The lat and longitude data which the system enters for my home is consistent with a location 1/10 of a mile west of my home.
The same thing has happened at other locations which are built up with houses all along the street and at commercial locations ie stores, where the street contains different addresses in adjacent buildings.
Logically, it would appear that the either the system is not inputting the correct address to be translated into lat & long or that the address is not being translated correctly into lat and long for the satellite.
Dealer says they talked to Hyundai America tech who claims they never had such a problem b/f---but I find it hard to believe I have the only car which ever had this problem.
You are not along....I have been back and forth with this problem for two years now on my 2010 Jinny and have received no satisfactory solution to the cause. They gave me one map update but this did not help at all. I usually use my hand held GPS when I go to an area that I am not familiar with. TWO YEARS....Hyundai needs to find another outfit to provide better nav software for them.
My nav system tells me that I have arrived at my destination when I actually have one block to go ( 1/10 of a mile). We are not along..:(
My NAV did this when I 1st bought it. I'd be sitting in my driveway and the NAV would show I have about another tenth of a mile to my home. However, for me this was corrected after my NAV update offered by Hyundai.
Hi,
What year is your Hyundai Genesis?
When did you get the Navi system updated?
Do you know what version of the software you have?
At this point, Hyundai won't tell me if they have an update, tho it's doubtful since I have a 2012 and it's relatively new.
Hi,
If you're referring to me:
1) 2009
2) Nav updated 1.5 years ago
3) Version 4/30/2010
Mine does the same thing. I still just use my Google Navigation on my phone. It's easier to input the destination and gets me better results. Oh yeah, I have a new 2012.
