NEED HELP LOCATING Crankshaft Angle Sensor Part # 39310-3C410 for 2012 Hyundai Genesis 3.8 Sedan.
Chrisdh43
I've watched all the You Tube Videos , read through all the threads, looked at all the pictures and I still can't find it. Supposedly its driver side located somewhere on the bell housing but I've moved things around looked with flashlight from the top ( supposedly it is removed from the top with wrench extension). But I can't find the thing to save my life. If someone knows where it is can you post some pictures, a video or anything to help me find it.
It's up high on the bell housing, looking between the back of the valve cover and the steel water pipe. Changed mine using a couple of long 1/4" extensions.
OZY44 - I can’t thank you enough ! Thats exactly where it was located now a $26 part on Amazon saved me hundreds of dollars! I reset the codes , no more check engine light and no more bad crankshaft sensor .
This worked 100% glad this is out there because all the other You Tube videos and posts here about this didn’t help . This picture shows exactly where it is an it is hard to find . I had to reach down in there somewhat blindly to loosen bolt and remove old one .
What about the 2013
........ As in 3.8L, 5.0L or4.6L ? If you have the 3.8, It's the same location.
