OEM Genesis wheel center caps
Rey
Salem, OR
I just replaced my Hyundai logo wheel center caps with Genesis logo wheel center caps. They Hyundai partr # is 52960 3M000. They fit perfectly. You need not remove the tire. The original wheel caps can be easily/carefully pried out with a knife tip. You are most likely to see these caps on eBay under "Hyundai Genesis" with no "sedan". You will also see R-Spec center caps. These are very basic 60mm center caps, and may also fit aftermarket wheels that use 60mm center caps. Here is one eBay source: http://cgi.ebay.com/ebaymotors/HYUN...r_Truck_Parts_Accessories&hash=item35abcb647d
How do you attach them to the wheels? Adhesive?
Did the same to my wheels.....
The caps snap in/out. They are held in place by several flexible plastic "prongs."
Weird, I removed mine just like I did on the V8 wheels. Used a heat gun to remove H and put the wings from V8 caps onto the R Spec caps.....
I have seen two different versions of center caps for the R Spec wheels. The first has the genesis wing logo already on a new center cap (Hyundai Part # 52960 03M000) and the second version is just a stick on that you put on over the H logo. The stick on version covers the entire existing H logo center cap. The wing logo seems to be printed on the backing.
If i understand Scottdk correctly it seems that there is a third version that is just the wing logo that you put on the existing center cap.
I have ordered the replacement center cap version and should hopefully get them soon. I believe what i ordered is the same as what Rey has but i can confirm once it arrives.
Funny Gorrilla! I have my wheel lock from the OEM wheels, but the lock is soooo huge in comparison the standard nuts that it looked terrible, so I left it off. We're pretty trustworthy in MN so I shouldn't have too worry:) I have about 2 months left before I store the car for the winter, so I'll enjoy the risk while I can.:cool:
