oil change
MARTINO442
genesis 3.8 2012 6 qts with filter usind 5 30 syn is this correct also what is the button for on the right side of my steering on the top with pict of a car? thanks
5-30 or 10-30, and I use Mobil One, but synthetic is not required.
I just bought anew Genesis V6. Two things about the oil in t he car.
1 - The dealer said they use a "synthetic blend" What is this? I normally take my cars to a Jiffy lube type place. Will they have this available? Is this just regular grade oil like I used in my 07 Azera?
2 - Shows 7500 miles between oil changes - seems like a long time for regular oil. I'm curious what others do.
Last question. . . .does anyone use premium fuel? Shows not required, but gives better performance. Is this true?
Thanks!
Don't waste your time on premium fuel.
A synthetic blend is an oil that is between regular "Dino" oil and a full synthetic.
If you aren't using a full synthetic, I'd stick with the 3,750 mile "severe" service schedule.
Thanks!
Some dealers use synthetic blend, but only conventional oil is required by Hyundai. Synthetic blend is a combination of conventional oil and synthetic oil (although mostly conventional) and it is better quality than 100% conventional oil, but obviously not as good as a full synthetic. I personally recommend a full synthetic oil, especially those with a GDI engine. I use a full synthetic and change my oil about every 5000 to 6000 miles. I use Mobil 1 0W-30.
The V6 is designed to run on regular, but I have noticed that I get better gas mileage with a mid grade fuel (or you can get 2/3 of a tank of regular and 1/3 of a tank of premium, which is cheaper than mid-grade). 100% premium is probably too much octane for the V6.
Went in for the normal oil service and was told about a recall on the brake fluid. Dealership will flush out old and put new brand of fluid.
Use 87 octane gas. Anything more is a total waste of money. Premium gas will NOT get you better performance.
All of a sudden - gas discussion - for the 10,000th time.
At least for the V8, Hyundai specs says it gets about 7 more HP with premium than with regular.
You're right. Mea culpa. I should have said "appreciable" performance. I use regular "non-ethanol" gas and get 3 more MPG than with Premium with ethanol. Cost is almost identical and I detest ethanol in my gas.
And gas has what to do with the OP's topic??
