Product Release - CMD fuel/boost tuner for Genesis 2.0T
DJ_Keith
Las Vegas, NV
FOR IMMEDIATE RELEASE:
Dynojet Announces a New Automotive Performance Product - the CMD for 2010 Hyundai Genesis 2.0T
North Las Vegas, NV, August 19, 2008- We are pleased to announce the following application addition to our Dynojet CMD product line.
The Dynojet CMD (Combustion Management Device) is designed to optimize the power of your OEM forced induction vehicle, while retaining the factory engine management system.
The CMD is loaded with features that allow the user to precisely alter the fuel, boost, and works in parallel with OBDII (including CAN-Bus systems). Designed to be “plug-n-play” right out of the box*, the CMD comes pre-wired with OEM style connectors for each specific vehicle, eliminating lengthy installation times and guesswork.
Features
• Direct injector control (+/- 100% fuel change)
• Fuel change based on MAP sensor
• Boost / Fuel cut defense (through TIP / MAP clamping)
• Boost Control (+/- 100% change)
• Plug-n-Play Harness with OEM style intercept connectors, no cutting or splicing is required
• Update firmware via USB, no need to return the CMD for updates
• Control Center Software™ allows for unlimited map possibilities and real time tuning (base map included)
• Up to 48x48 tables dimensions allows for fine tuning and precise control
• Works in parallel with OBDII vehicles, even CAN-Bus systems
• CMD can draw power through the PC USB port, enabling map changes with the ignition off, or remove the CMD from the vehicle and bench program
• CAN-Bus communication and expansion options yields lightning fast communication speed with the Wide Band 2, LCD Display, and other Dynojet products
*The pre-release version of the CMD will come with a partial plug-n-play harness. As of 8-20-09, this harness includes the male/female injector connectors, boost solenoid connectors and crank connectors. As more of the connectors come in, we will add them to the harness. Final release version will include male/female plug-n-play connectors for the injectors, TPS, TIP, MAP, crank and boost solenoid connectors.
The CMD installed on a completely stock Genesis 2.0T yields impressive gains. 76lb-ft of torque and 49hp in the midrange, with peak gains of 71lb-ft and 33hp!
Product pictures and screen shots from the Master Control Center software:
CMD module shown with complete plug-n-play harness (Subaru WRX/STi)
Fully user customizable interface. Setup your own gauge screens with round analog gauge faces, 1/2 round gauges, digital gauges, bar graphs, etc. Logging directly from the CMD to your computer via USB plus live view on the gauge panel. Logs can then playback on the log/graph viewer as well as synchronized with the gauges. Histogram population during log playback for easy copy/pasting of clamp values.
The Control Center software allows for fuel adjustment in a 48x48 cell table for fine resolution of adjustment. In the case of the Genesis, the left axis is the MAP sensor. Fuel change is expressed as % change from stock. Allowed values are +/-100% from stock.
The boost table allows for either an offset or open-loop strategy. Typically we run them in offset, and just add or subtract solenoid duty cycle as needed. The Genesis is quite sensitive to boost solenoid changes and only needs 20-30% increase to achieve +10psi over stock.
The MAP and TIP clamp tables allow us to limit the output back to the ECU from the MAP and TIP sensors, to keep the car out of boost cut/limp mode. While the stock ECU doesn't see the additional boost, we can still fully map the fuel curve according to the original sensor readings.
The CMD-1810 for the 2010 Hyundai Genesis 2.0T will retail for $449 with the complete plug-n-play harness. Currently we are offering the pre-release version at $419, and on top of that, Genesisowners.com members can PM their order to us here for an additional 10% discount! That's right, be the first in your neighborhood to have a CMD on your Genesis 2.0T for only $377!
For additional information, check out the CMD website at http://www.dynojetcmd.com
If you have any further questions, you can PM me here, e-mail us at sales@dynojetcmd.com or call us at 800-992-4993.
Product update - The CMD can now display and log wideband readings in it's Master Control Center software when used in conjunction with our WB2 wideband device. The next addition to the software/firmware will be the ability to AutoTune - or have closed loop control on the WB2 wideband data.
We're getting closer! The last of the pre-production harnesses are here. These will be tested Monday and then sent to our distributor in Korea. The first of the production harnesses should be here Wednesday or Thursday!
The Dynojet CMD is now released with the full plug-and-play wiring harness. At $449 retail, Genesisowners.com forum member can take advantage of the 10% member discount.
We have even achieved 290rwtq with our test car - all stock with just the CMD installed!
fantastic post.......i really liked this all detail and thread of urs, just liked it and saved it into my computer.....
