Rey
The R-Spec intake can be easily and cheaply modified to produce more power and even better gas mileage. I have over 15K miles on this mod. with no material downsides. It is louder on hard acceleration, but normal light acceleration and cruise it is just as silent as OEM.
The air filter I use is a K&N "RF1040". It costs about $50 online. The reason I choose this particular filter is its size. It is one of the largest aftermarket filters available. Filter size matters - more filter area, less restriction=more power.
With the filter in hand you just remove the OEM airbox and attach the K&N to the airbox connector. It slips on and needs no further support. I did some before/after comparisons of ambient air temp vs. intake air temp; and I found this mod does not materially increase the differential at highway cruise.
On the same subject is the size of the throttle body. Adding a larger throttle body is quite a common mod with Corvette owners. The ECU automatically compensates for the increased airflow. Unfortunately, there seems to be no source of larger aftermarket throttle bodies for the R-Spec. BUT, there is a source that will enlarge your throttle body. http://www.maxbore.com/maxbore.html.
