dudmleh522
- Jan 18, 2010
For ur v1 do u have a remote mute button like escort? Is wiring to the mirror lot easier than fuse box?I hardwired my R3 into the mirror. No remote, just reach up and mute it. I might install a BlendMount at some point but it's fine right now.
And that is same way to add dashcam?No remote used on my newly retired V1. As far as the hardwiring, it's a TON easier than routing to the fusebox.
Follow this thread (w pics) How to get to the wiring harness for rear view mirror on 2015 Genesis 3.8 AWD?
Oh thats right. Thanks!! i will try to hardwire today or somethingGood question, probably but I don't know about dashcams that use park mode because it would need power when the ignition is switched off. A multimeter would probably be the best source to tap the mirror wires in this case.
Use a rechargeable Lithium powered dash cam. No need to hardwire one into the system. There are quite a few excellent dash cam available that are lithium rechargeable. I believe one is advertises here in the vendor section. Keep in mind, anything that is hard wired unless turned off is a drain on the Genesis battery. You have to make sure it's turned off individually or it will be a draw on the system. It may leave your battery flat after a short period of time.
https://www.amazon.com/LG-Innotek-2-Channel-Dashcam-LGD521/dp/B01N4DMVQH .That's going to seriously limit the number of dashcams you can buy. The rechargeable battery packs for some of these (Blackvue for instance) almost exceed the price of the cameras...and they still need to be hardwired somewhere.
