Right Rear shock replacement. Anyone ever done this job?
StevenThomas
2012 Genesis Sedan 3.8 - blown right rear shock and need to fix this asap
I was very surprised the inspection station failed me for a blown rear shock. I figured I would order the shock off amazon or rockauto and do the repair myself. After searching all over, I can't seem to find a replacement available. I found a few things but nothing like I was expecting. I called the dealership and they said it would take up to 10 business days to get the part.
Has anyone else ran into this issue with a rear shock being blown anda DIY replacement ?
Removal
1.Loosen the wheel nuts slightly. Raise the vehicle, and make sure it is securely supported.
2.Remove the front wheel and tire (A) from rear hub.
.Support the lower portion of the rear axle with a jack securely.
4.Loosen the bolt & nut and then separate the rear shock absorber
5. .Disconnect solenoid ESC & wheel speed sensor connector and then remove the wheel speed sensor bracket by loosening the bolt.
6.Loosen the bracket bolt (A) to disconnect the rear shock absorber from the wheel housing panel.
7.Screenshot_20200221-120712_Hancom Office Editor.webpScreenshot_20200221-120726_Hancom Office Editor.webpInstallation is the reverse of removal. 8.Check the alignment.
Shocks should always be replaced in pairs.
