- Mar 7, 2016
Gen 1 side view mirrors aim down when the car is put in Reverse - if the mirror adjust switch is in the "L" position, both aim down, and if the mirror adjust switch is in the "R" position, only the passenger mirror aims down. Not sure how Gen 2 mirrors compare.
However, at any rate, the issue with mirrors adjusting themselves and not holding their position is caused by faulty position sensor in the mirror which erroneously reports a needed adjustment to match memory settings. IOW, the mirror is telling the ECU that it is out of position from assigned memory settings and needs to be adjusted one way or the other. I had this issue in a previous luxury vehicle and the fix was to replace the side mirror assy.
Hope this helps!
Hope this helps!
