dlanger2
- May 21, 2020
- Equus (2011-2016)
Hello friends.
I own Genesis 2012 Sedan 3.8L V6.
I've read the codes and had the following list((
Smart Cruise Control Codes:
C1101 Battery voltage high
C1102 Battery voltage low
C1202 Front Left Wheel speed sensor invalid/no signal
C1205 Front Right Wheel speed sensor invalid/no signal
C1208 Rear Left Wheel speed sensor invalid/no signal
C1211 Rear Right Wheel speed sensor invalid/no signal
C1260 Steering Angle Sensor Circuit-Signal
C1283 Lateral G sensor /Longitudinal G sensor/ yaw rate sensor: signal error
C1360 ESP Irreversible Error
C1603 ECU Internal Thermal and Voltage Error
C1604 ECU Hardware Error
C1605 CAN Hardware error
C1606 ECU Software Error
C1611 Lost Communication with EMS or ECM
C1612 CAN time-out TCU or TCM
C1613 CAN Wrong Message
C1616 CAN Communication Bus Off
C1617 EMS Invalid Engine Speed
C1620 First Setup Not Completed
C1622 CAN Wrong Message for EMS_H2
C1623 Lost Communication with Steering Angle Sensor
C1625 CAN time-out ABS/ESP
C1628 CAN Timeout - Cluster
C1629 Cluster Invalid Counter
C1632 MDPS torque sensor sub signal fail
C1633 MDPS torque sensor signal fail between main and sub
C1634 MDPS torque sensor voltage fail
C1635 TCS Invalid Counter
C1636 TCS Invalid ACCEL_REF_ACC
C1637 TCS Invalid aBasis
C1638 ACC/SCC Communication error
C1642 CAN message failure
C1646 CAN Message Failure - TCU
C1680 VSM EBS Error
C1702 Variant Coding Error
Occupant Detection System Codes
B1489 PODS (Passenger Occupant Detecting System) ECU Defect
B1496 PODS (Passenger Occupant Detecting System) Not calibrated
B1495 BTS (Belt-Tension Sensor) Defect
B1493 PODS (Passenger Occupant Detecting System) Communication error
No error lights on the dashboard.
About 6 weeks ago, had the battery died with no reason when the vehicle was parked. Jumped the battery by AAA.
Since then no visible issues. Cracking the engine fast. Headlights are stable on the battery and with the running engine.
About 5 weeks ago, the engine has stopped when crossed the road bumper (was driving a little bit too fast).
Just started the engine and moved on. No lights came up on the dashboard as well.
Kind of suspecting for the voltage / alternator fluctuations, but it seems like only the cruise control system doesn't like it (
C1101, C1102). And again, no error lights on the dashboard.
The error lights function (confirmed with the switch ON).
Checked the leads on the battery in the trunk and under the hood. Tight and clean.
Control voltage when the engine is idle (600rpm) is around 14V.
Would like the hear your opinions please, before heading to the dealership.
Thank you!
C1680 VSM EBS Error
Thank you!
