vega
- Jun 3, 2010
- Genesis G80 Sport
Let's say you are set to 50 mph. This is indicated in the center of your instrument cluster as the digits 50. Tapping it once brings the new speed set up to 51 and naturally the car accelerates to accomodate the new speed. On the other hand, if you would have tapped it 5 times it would have been set to 55. Here's your problem, holding it for more than 1 second will cause it to increase 10 fold as in jumping from 50 to 60, keep holding and it will jump to 70 etc. According to the way you say it is supposed to work, it sounds like you inadvertently set it to 10 or 20 or more miles per hour over what you were initially set at so naturally it feels like it is accelerating until you apply the brakes. The + button is not an accelerate button, it is a speed set increase button and also serves as a resume to speed button if you needed to slow down using the brakes.
thanks for the reply,
this is from the owners manual smart cruise control section
To increase cruise control set
speed:
Follow either of these procedures:
• Push the RES+ switch and hold it.Your
vehicle set speed will increase by 10
km/h or 5 mph. Release the switch at
the speed you want.
• Push the RES+ switch and release it
immediately. The cruising speed will
increase by 1.0 mph (1.6 km/h) each
time the RES+ switch is operated in
this manner.
• You can set the speed to 113 mph (180
km/h).
To decrease the cruising speed:
• Push the SET- switch and hold it. Your
vehicle set speed will decrease by 5
mph or 10 km/h. Release the switch at
the speed you want.
• Push the SET- switch and release it
decrease by 1.0 mph (1.6 km/h) each
time the SET- switch is operated in this
manner.
• You can set the speed 18.6 mph (30
km/h).
In both instances it states to hold the button until you reach the desired speed, then release at the speed you want. In either direction my car will accelerate / decelerate until the cruise kicks out, @ 10mph and 113mph.
The single press works perfectly, up or down 1mph.
