G
G-799527
The rubber bumper plug can also not be the right size. I suspect mine has shrunk with age and isn't depressing the switch correctly.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Can you take a picture of it pleaseHi Ron,
Do you have the name of the rubber part and where to purchase. Or what it's name is. My daughter has been having this problem for a while now. Or do you know of any photos or viseos related to this issue we coud search.
I've tried to look for videos but niether of us are mechanics and when I try and do a search many different things show up.
Thanks for posting this in the forum
I look just where you told me and that rubble piece that goes over that button was off look like something else should be in the top to push that button I don't know but I did remove one of those rubble pieces that was in the top of my hood and placed it there Just in case If yours have something over it to activate that but let me knowI found the switch and the rubber stopper is in place.
Thanks, Bob, for your help.
Ron
0.03 mA (0.00003 Amps) is pretty much nothing. I'm sure you/he meant 30 mA (which is 0.03 Amps). Generally, anything at or less than 50 mA is not a problem. Either your battery has a high internal self-discharge (it does happen once in a while), or perhaps more likely, you have a way higher drain than 30 mA that comes and goes and didn't show itself during their short test.... it showed a normal draw of .03 milliAmps (he said normal range is .03-.045). ...
Thanks for the clarification on the mAmps, yes I believe the tech did say "30 mA" now that you say that. The tech called about 5 hours after I left it and asked if they could keep it overnight to run an extended test of the draw. That was fine with me. They still didn't see any unusual draw. The battery steadily loses charge over a short time, however - as I mentioned, it drained from 100% to 72% after about 4 days with no driving.0.03 mA (0.00003 Amps) is pretty much nothing. I'm sure you/he meant 30 mA (which is 0.03 Amps). Generally, anything at or less than 50 mA is not a problem. Either your battery has a high internal self-discharge (it does happen once in a while), or perhaps more likely, you have a way higher drain than 30 mA that comes and goes and didn't show itself during their short test.
can somebody please take a picture of what is referred to?I experienced the same problems. ( Genesis 3.8 2009) My battery went dead after the car sat for three or more days. Dealer kept replacing the battery. I am now on my third battery in 16 months.
Car went dead this past weekend after a four day sit and was towed to the dealer. I mentioned to the service manager the hint about the rubber bumper.
An hour later he called to thank me for the hint. The bumper was misssing.
I hope that my days of changing batteries every six months, (under warranty of course) are over.
Pity that Hundai service techs don't read the forumsc
yes, can a picture of such please be shownCan you take a picture of it please
I'll bet it is the following.
Lift the hood. Look just inboard of the driver side fender, for a push switch.
Next look at the hood, near the edge, in the area where the hood closes over that driver side switch. You SHOULD see a rubber stopper, that pushes down on that switch. If the rubber stopper is missing, you will see the hole where the robber stopper belongs. If rubber stopper is missing, this is your problem.
If rubber stopper is there, and it does push down on the push switch, your problem is elsewhere.
