ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
The only major probelm I've had with the steering column memory is that didn't seem to work at times in very cold weather, especially if the car had been sitting out in the cold for a long time.
In very cold weather, its not the steering column that gives me problems, but the memory for the seat. When I park outside in cold weather, and start the car up, yes, the seat goes up to the memory position, however it will not return the the rest position when I shut the car off. In addition, while in the driving position, if I try to use the switch on the side of the seat, it will not go back, but sometimes it will go forward. I've learned that when the seat starts to act up like this, to not push the seat switch forward, because I will not be able to get the seat to return back to a comfortable position. After the car has been driven for a while, and the interior of car has warmed up, only then will the seat return to the rear position when shutting off the car.
This has happened to me twice, once in Penfield NY last May and again in Roswell NM last December.
This problem is in addition to the steering column problem.
