Hello all,
I bought some Supertech Extended Life coolant and I’m wondering if it’s good in our cars.
Link to Walmart
Thanks
I don
t see why not. It says it is for all engines and the manual does not specify anything special
Recommended engine coolant
• When adding coolant, use only
deionized water, distilled water or
soft water for your vehicle and
never mix hard water in the coolant
filled at the factory.
• An improper coolant mixture can
result in severe malfunction or
engine damage.
• The engine in your vehicle has aluminum
engine parts and must be
protected by an ethylene-glycolbased
coolant to prevent corrosion
and freezing.
• Do not use alcohol or methanol
coolant or mix them with the specified
coolant.
• Do not use a solution that contains
more than 60% antifreeze or less
than 35% antifreeze, which would
reduce the effectiveness of the
solution
