daviderle
- Nov 17, 2008
I have been trying to resist the urge to comment on this subject, but this thread seems to have few misconceptions and we do not appear to get to any reasonable conclusion, therefore, it may be a good time to quote (somewhat) a reliable reference:
"Octane rating or octane number is a standard measure of the performance of an engine or aviation fuel. The higher the octane number, the more compression the fuel can withstand before detonating (igniting). In broad terms, fuels with a higher octane rating are used in high performance petrol engines that require higher compression ratios
Petrol engines (also referred to as gasoline engines) rely on ignition of air and fuel compressed together as a mixture without ignition, which is then ignited at the end of the compression stroke using spark plugs. Therefore, high compressibility of the fuel matters mainly for petrol engines. Use of petrol (gasoline) with lower octane numbers may lead to the problem of engine knocking".
So, in the Genesis case, the use of low octane is less of an issue in the Pre MCE (2009-2011) MPI engines, while the 2012-2015 GDI engine may present a bit more of a challenge due to the higher compression ratio (which resulted in the higher HP/TRQ numbers). The engine timing can indeed adapt in both cases, but I personally find the knocking and the black soot on the back bumper is too much in order to save few dollars in my R-Spec, while I am happy to use regular 87 most of the time in the 4.6 2009.
Hence, my personal conclusion: there is enough evidence to go either way, so it seems this thread maybe more of a personal preference than a technical discussion..
Reference: http://en.m.wikipedia.org/wiki/Octane_rating
