Terrible smell from the A/C
If it is like my 11 Azera - AUTO will recirc to cool the car down, then switch to fresh. That being said - I also have the smell problem for a couple moments after starting the car. Gonna have to try some of these tricks to fix the issue. Thanks :)
This is a design issue that should not happen in 2015. I have never had this issue in any other car I've owned - and they were all previously much less expensive cars!
Living in San Antonio, Tx, I had this problem during our "wet" months. Now that we've had over a month with little to no rain, 100 degree temps and low humidity, the issue resolved itself. One of the benefits, I guess, of living in this climate...until the winter rains start.
I have found that if you spray Lysol Disinfectant Spray in the intake just below the glove box while the AC is on Recirculate/High fan speed just before shutting the car off at night, this resolves the problem after a few applications. I leave a can on the workbench and spray it and the second I can smell it, power the car off.
This would be even more effective with the cabin filter removed but the filter has noting to do with the resolution of this problem.
BG Services Frigi-Clean and Frigi-Fresh are also great products for this.
https://www.bgprod.com/catalog/climate-control/
I did what was suggested above, and it didn't help at all. So that leads me to think that the mold is residing outside the recirculation path. Others have suggested that I spray Lysol directly into the cabin air filter. Does that reside outside the recirculation path?
Is the evaporator draining condensate on the ground as per design (with the recirculate function off)?
Mine is dumping water like crazy right now (Wash. Wx).
Mine is not dumping water like crazy even after heavy use of A/C in this humid city.
I wonder if it's a design flaw -- as others have suggested -- of Genesis 2015, or a problem with my car.
Dealing with this now, pretty unacceptable for a $50k car. Shouldn't warranty cover this?
If your AC drain hose is not dumping condensation water onto the street, or driveway, then it is probably clogged. Did you investigate/inspect that possibility? If water is not being discharged through that drain then you've found the problem.
It's been extra warm in the northeast over the past week and I started to smell mildew after startup. If I run the fans on high for 20 or so minutes, the smell seems to go away but comes back after the car sits for a few hours. Anyone else in NE noticing this?
Yup - NJ. I had the dealer deodorize/sanitize a few weeks ago. It never fully went away and is starting to get noticeable again. There appears to be a design flaw here! It's going back in for replacement of major sunroof parts on Thursday, so I'll bring it up again. Very disappointing in a car that costs this much - my daughter's 2006 Sonata has no issues with AC smell - nor has any other car I've ever owned!
Car is dumping plenty of water so must be a low spot in the design somewhere that doesn't drain!
Car is dumping plenty of water so much be a low spot in the design that doesn't drain!
Man that's a bummer! I'd take mine in, but worry they'd spray some sort of "flavored" deodorizer. Good luck with the roof replacement!
Had that happen on a BRAND new 2006 Sonata years ago - Brand new from the dealer, apparently, had a critter living in the air box (where the cabin filter is). If it's biological in nature, it very well could be a dead critter.
maybe something crawled up in there and died. never know.
More water = more mold.
In humid climates, such as where I am in Florida, running the air on recirc reduces the cabin humidity and therefore reduces the amount of condensation on the evaporator.
Worst thing you can possibly do is to run the AC on recirc, get everything really cold and change to fresh and pull in lots of damp outside air, which then condenses all over the interior ductwork, etc., and then shut off the car. That leaves the system soaking wet, where mold will flourish.
Best thing you can do is run the system in recirc 100% of the time. That keeps humidity lowest everywhere in the AC system and in the car.
Less water = less mold.
Another technique to help mitigate mold is to turn the A/C compressor OFF but leave the fan running for the last few minutes of your drive. Basically have the fan dry out the evaporator assembly before you park the vehicle. Works in pretty much any car, not just the Genesis. Recirculate or fresh air works for this but recirculate prevents the introduction of outside humidity/moisture as Gunkk posted.
For folks that have chronic mold buildup issues I'd check:
1: the area underneath the windshield wipers has drains to the ground. Leaves and other debris often collect in these drain tubes leading to standing water in the grill area. This is where many cars draw in fresh air. A thin wire stuffed up the drain holes (from underneath the car... often they're just openings in the sheet metal instead of actual hoses) to poke out crud makes a world of difference.
2: The evaporator assembly (the box underneath the dash on many cars, or attached to the engine-side firewall on others, it's the actual part that cools the airflow and thus makes excess humidity/moisture condense back to water) has a drain tube through the floor of the vehicle or through the firewall at the base of the evaporator box. This is another area that gets plugged with leaves and debris (you'd be amazed at how much leaf-like crud collects in car ducting!). When this drain hose is plugged, water just sits in the evaporator housing like a bucket promoting mold/mildew growth. Eventually the water depth gets high enough that it finds seams/joints in the plastic housing and leaks onto the passenger side carpet. Messy. Again, a wire poked through the drain hose can make a world of difference. If you crawl under the dash and pull the carpet back you can often find the drain hose... unplug it and have a bucket ready to catch the water that'll pour from the evaporator box and then use a "J" hooked shaped piece of wire to fish around the drain hole in the box.
An easy way to test these drain lines on many cars is to get a fresh piece of hose that'll fit snugly over or snugly into the drain hose. Then blow air INTO this hose. If air flows fairly easily the drains are clear - great. Hear bubbles? Something is blocked and you've got standing water. Can't blow air at all? Really plugged... Be ready for a sudden water flow if you happen to "unplug" the lines while blowing... that water will probably taste horrible! A small tire inflator, air mattress foot pump, etc. might be a more hygienic method. Use no more than 10psi pressure. (healthy lungs can generate up to 2psi for most folks)
In addition to water drain holes in the wiper cowling area, car doors also have drain openings along the bottom edge. This lets any water that gets in via the window openings drain out. Hardly anybody ever checks/cleans these which is why older cars often have lines of rust along the bottom edge of the doors. The area behind the front fender (between the wheel and front door opening) is another area that frequently has leaves and dirt buildup on cars... this crud holds moisture against the sheet metal promoting rust/rot from the inside. A vacuum with a crevice tool/nozzle gets a lot of this crud out. The 1G Genesis sedan has some sealant material in this area to minimize this crud accumulation. Keeping these drain holes clean will prevent rust and minimizes moisture in the doors, bodywork, etc. that can also breed mold.
mike c.
mike c.
Great tips, thanks. Thanks to Gunkk too!
I don't know why more people aren't LIVID about this. You bought (or leased) a $40K+ car, in some of our cases, $50k+ car. I don't know about you guys/gals, but my family/clients are in this car and having them inhale MOLD is not something I signed up for. Dealer is giving me BS, Hyundai is "investigating" the issue. This is absolute shit. About to take this one to the press.
I am livid. I have tried everything. There is no rotting debris buildup any where. I have replaced the cabin filter and sprayed the HVAC disinfectant from TP Tools many times. I love the styling, the V8 performance and all of the tech that comes with the 5.0 ultimate. But the stench from the HVAC, the smell in the trunk, the rattles from the sunroof/liner, the finish peeling off of the gear shift and the most annoying constant rattle from underneath the front end (the plastic cladding?) this car is really pissing me off. $56k and inept customer service doesn't help. I should have kept my 2011 4.6 and next time I think that I will be in an Audi or Cadillac.
Have you contacted Hyundia Corp directly ??? If you did did you get a file # ??
Email this guy about all your problems
Dave Zuchowski
dzuchowski@hmusa.com
Let us know what happens
Have you contacted hyundai Corp directly ??? If you did did you get a file # ??
Dave Zuchowski
That's what I did and he responded within 20 minutes and got HMA involved with my sunroof rattles. They have replaced most of it in the last week. The nice part is that the dealer was told they could not release the car to me until the HMA rep confirmed it was fixed. She came out this AM and test drove the car and was not satisfied - so they are now doing additional work - at least it's getting attention and I'm hoping they've resolved it. However, I really think that the roof has design flaws - the loaner I'm driving has the rear panel gasket peeling away and, while quieter than the roof my car, still has some rattles and shifting noises.
The cowl service bulletin might resolve teh AC smell issue?
Same issue. I do not want to waste my time going to the dealer since they are just turning on the heat and saying it is fixed, and it sure is not fixed.
I submitted this issue to Hyundai and asked when they are opening a service bulletin or performing a recall?
Contact them at the link below to push this issue.
http://www.HyundaiUSA.com/contact-us.aspx
Here is what Hyudai had to say, basically "set the air vent to fresh air not recirculated" well.. it has been on fresh/outside air all the time...
"Further research was conducted and we found information that may assist you in resolving your in-cabin air quality concern. Please review the 2015 Genesis Owner's Manual in section 3, page 133 which refers to the Automatic Climate Control System. Undissipated humidity can have short and long-term negative consequences. Please note that on page 141 is a reference to prolonged operation in the recirculated air position which may allow may allow humidity to increase inside the vehicle. On page 143, further advice is provided to, "Be sure to return the control to the fresh air position... to keep fresh air in the vehicle." Again on page 145 is another reference to the importance of utilizing the fresh air intake to avoid the air quality inside the vehicle becoming 'stale'. "
