I wanted to share the reset fix that has been discovered. I did not figure it out but I think MikeC did. Anyway the below proceedure seems to work for many that have the tilt
wheel memory/reduced motion problem.
Originally Posted by zimmerman80
Holy cow! Mine just worked too. I have a 2010 Genesis V8 w/tech, and it is a later model that required a steering column replacement once before. As mentioned above, with the car not running, I moved the steering
wheel down as far as it would go holding the switch down for around 10 seconds. Then I moved the
wheel in towards the dash, also holding that down for around 10 seconds after it stopped moving. Then when I pressed 'up', it went all the way!
After starting and stopping the engine, the memory system seems to be back again. Although this is annoying, it is a lot better than needing the dealership to do it each time.
Posted by Homeofstone..I had noticed in the last week that my steering
wheel was not going up as far as it use to on the exit function. Tried this and presto! all is back to normal with full motion. Thanks for this reset fix, it is soooo easy.
Posted by GenesisV8tech.....Yes, the reset procedure did the trick and the steering column now has a full range of motion. I left "easy access" feature on and the steering
wheel does not seem to be creeping down the dashboard so far(one day) every time I start the vehicle. The previously remembered positions of seat and
wheel are getting where they were before I pushed the stop button.
